Need schematic or boardview for HP 14-cm0012ax
  • vampy999
    • Sep 2019
    • 110
    • malaysia
    Anyone have?
  • vampy999
    • Sep 2019
    • 110
    • malaysia
    Re: Need schematic or boardview for HP 14-cm0012ax
    need bios too, thank you
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      what is the motherboard reference?
      • vampy999
        • Sep 2019
        • 110
        • malaysia
        Board p/n : 14-FP5-6L-GDDR5X2
          • 21889
          The bios dump has been moved to the "Bios Requests ONLY!" section. Bios dumps don`t belong in here
          https://www.badcaps.net/forum/showthread.php?t=89370
          • suntech89@yahoo.com
            • Jan 2020
            • 9
            • Pakistan
            14-fp5-6l-gddr5x2
            continously running Fan
            Plz I need Help.
            • gardiuz
              • May 2021
              • mexico
              Originally posted by suntech89@yahoo.com
              14-fp5-6l-gddr5x2
              Plz I need Help.
              did u solved?
              • vvulture
                AMD Radeon VII Reference Design Schematic/Boardview
                by vvulture
                Hi guys,
                Would anyone here have schematics and boardview files for the reference design AMD Radeon VII board ? Need to fix fan circuitry damage.
                Thank you
                03-26-2024, 10:36 PM
              • PacoGT
                HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                by PacoGT
                hello firends
                i search the schematic or boardview
                I have this motherboard, but I can't find the schematic or the boardview.
                The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                So the computer doesn't turn on, and the 3V disappears after a few seconds.
                The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                The new problem arose after removing the bad chip.
                3V and 5V remained together,...
                08-19-2025, 08:25 PM
              • hosain0489
                Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                by hosain0489
                I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                Thank you very much in advance!
                07-15-2025, 11:20 AM
              • re-atari
                Gigabyte GA-H110-D3A schematic/boardview needed
                by re-atari
                Hello all,
                Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                02-24-2025, 06:45 PM
              • jonyhdtv
                HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                by jonyhdtv
                Looking for schematic and boardview
                Model: HP ProBook X360 11 G3 EE
                Serial: SCG9114JG7
                Motherboard: L43774-601
                defect: touchscreen doesn't work (touch works on another computer)
                thanks to all​
                01-29-2025, 08:16 AM
