BIOS dump for 14-FP5-6L-GDDR5X2
  • b171331
    • Oct 2014
    • 16
    • SRB
    HP 14-cm1600na
  • dennison flores
    • Apr 2021
    • 22
    • Philippines
    Re: BIOS dump for 14-FP5-6L-GDDR5X2
    HP 14-cm1600na
    is it working????
    • peste
      • Dec 2016
      • 13573
      • ROMANIA
      Originally posted by dennison flores
      is it working????
      make a backup of your bios and try it..if it doesn't work post the full name and model of the laptop and the bios backup ..
      • jimore
        • Nov 2020
        • 179
        • mexico
        original bios
        • Cba_Notebook
          • Sep 2021
          • 3
          • Argentina
          Ok for HP hp 14-dk0736ms
          Thanks!!!
          • lonelybdy
            • Oct 2020
            • 1
            • Turkey
            HP 14-cm1600na
            hp 14-cm1000nt amd onboard vga
            • suntech89@yahoo.com
              • Jan 2020
              • 9
              • Pakistan
              14-fp5-6l-gddr5x2
              continously running Fan
              Plz I need Help.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12326
                Originally posted by suntech89@yahoo.com
                14-fp5-6l-gddr5x2
                Plz I need Help.
                Your original corrupt bios file ? Your device's serial number ?
                • denilloo
                  • May 2013
                  • 60
                  • indonesia
                  Re: Need schematic or boardview for HP 14-cm0012ax
                  Try this
                  • ajbernasko
                    • Mar 2022
                    • 229
                    • ghana
                    I tried not okay, crashes and cannot load windows
                    • ajbernasko
                      • Mar 2022
                      • 229
                      • ghana
                      i HAVE ADDED MY BIOS IF NEED TO CHEC AND CORRECT FOR ME./ THANK YOU
                      • Jonatang
                        • Oct 2022
                        • 2
                        • Colombia
                        good morning, could you help me to correct this bios file, thanks
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12326
                          HP Notebook - 14-cm1025la
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12326
                            Serial : 5CG9295GNJ
                            • ajbernasko
                              • Mar 2022
                              • 229
                              • ghana
                              Serial : 5CG9295GNJ
                              Will work for AMD please ?
                                • 21857
                                14-cm1025la specification AMD Ryzen 5 3500U https://support.hp.com/uy-es/document/c06364908
                                • ajbernasko
                                  • Mar 2022
                                  • 229
                                  • ghana
                                  It still crashed, i think i have ryzen 3 instead of 5
                                  • ajbernasko
                                    • Mar 2022
                                    • 229
                                    • ghana
                                    hp notebook - 14-cm1025la
                                    serial : 5cg9295gnj
                                    crashed again
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12326
                                      crashed again
                                      Check your hardware, that's a virgin bios.
                                      • ajbernasko
                                        • Mar 2022
                                        • 229
                                        • ghana
                                        Okay, where should i check plss
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
