Can anyone provide me with Aclu3/aclu4 uma nm-a362 Schematic?
Lenovo G50-80 ACLU3/ACLU4 UMA NM-A362 SCHEMATIC
Tags: None
Re: Lenovo G50-80 ACLU3/ACLU4 UMA NM-A362
PU701 is burned i nned to replace it but i don t have schematic.
Anyone have this schematic please or if can read model of this chip its near wifi. -
there is a possibility that IC is SY8868QMC, but not sure 100% (just guess)
Hard to find schematic, HD images or BV for this platform, only see on ebay but the pics have poor quality. and the worst thing is impossible get datasheet about silergy's product
the refer only ACLUA schematic
https://www.google.co.id/url?sa=i&rc...77569614546323
once again its only guessComment
you have right this is the ic i can read KT on burned ic, i will order it .thanksthere is a possibility that IC is SY8868QMC, but not sure 100% (just guess)
try thisAttached Filesif you find these attachements useful please consider making a small donation to the site
I think Elvikom only provide HD image, not schematic.Originally posted by gcomputersHi please anybode an download schematic here :
https://www.elvikom.pl/schemat-lenov...6.html?lang=ru
i need to reprogram Ec ITE but my software Vertyanov dont have this model so i need to put it manually and i need SCHEMATIC for this.Comment
Lenovo G40-80 NM-A362 schematic needed
hi everyone please give schematic for this model Lenovo G40-80 notherboard id:ACLU3/ACLU4 UMA NM-A362 REV 1.0. I need to find SIO switching pin pleaseComment
Re: Lenovo G40-80 schematic needed
can someone help me to find the SIO switching pin for this laptop model board pleaseComment
I have this may help you..... i download it from chinafix
G40-70 & G50-70Attached Filesif you find these attachements useful please consider making a small donation to the site
on page 44 i cannot find the switching pin for ITE8586 can someone help me on this pleaseComment
can someone confirm me if schematic is right for it8586e switching pin is right at pin110 PWRSW# ? because in the board the ITE is lenovo IT8586E.please help thanks in advanceComment
I presume the scheme NM-A362 lenovo G40-80 who can make available I thank you.Comment
by G_seneHi, everyone.
I have this notebook that won't charge.
In Windows, the charger icon doesn't appear on the battery, but the charger turns on the notebook normally.
PU301:
Pin 5 (ACOK) - 5.97v
Pin 6 (ACDET) - 1.83v (should have 2.6)
Pin 16 (REGN) - 6v
PQ308 has no gate voltage, so it doesn't drive PQ309 low
With the battery connected, its voltage goes the reverse way to the jack, having 14v and not 20v:
PQ301 e PQ302
Pinos 1,2,3 14v
Pino 4 5v
Pinos 5,6,7,8 com 14v... -
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by paolottoLenovo 80e5 g50-80 ACLU3/ACLU4 NM-A361 rev.1.0
hello I would like some help, my laptop Lenovo 80e5 g50-80 ACLU3 / ACLU4 NM-A361 rev.1.0 does not turn on. when I insert power the led4 flashes and the fan moves a little. I only found the diagram pdf 2014-09 -10 REV0.4. I would need for BoardViewer the version for my ACLU3 / ACLU4 NM-A361 rev.1 and also schematic pdf. Also doing measurements with the multimeter I find on the line + 1.35_VGS to ground 6.06 ohm. According to me too low.
am I facing a short circuit?
that line affects the rams soldered on the board
thank... -
by zakiyyHello,
Lenovo G50-80 (ACLU3/ACLU4 UMA NM-A362) Rev 1.0
With battery laptop work perfectly ! But with charger no power and not charging ! What can be the problem??
Direct from Charger PIN no connect to laptop: 20.v
PQ301 (4407A)
Drain: 20v - 19v 17v fluctuating
source: 19v - 18 -16v fluctuating
Gain: 19v - 18 -16v fluctuating
PQ302(4483a)
Drain: 2.5v then 5 then 10v then 11v sometimes18 then again 2.5v again and again..
Gain: 19v - 18 -16v fluctuating -
Lenovo 3000 Series Schematic
Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
3000 C100 laptop with Braille keyboard
Lenovo 3000 C
C100, C200 - 15-inch XGA screen
Lenovo 3000 N
N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
N500 - 15.4 inch screen.
Lenovo 3000 V
V100, V200 - 12.1-inch WXGA models
Lenovo 3000 G
G400, G410, G430, G450, G455, G510, G530, G550, and G560...-
Channel: Schematics and Boardviews
10-04-2024, 06:05 AM -
- Loading...
