Clevo U953 or Purism Librem 15v3
  • handle
    • Apr 2019
    • 20
    • Italy
    I have a problem with the Purism Librem 15v3, which has a mainboard derivated by the Clevo U953.
    I'd appreciate if someone would like to share the schematics of any of these twos.
  • Günter Schuch
    searching for Schematics & Boardview for Clevo P641HK1
    by Günter Schuch
    hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
    Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
    05-14-2025, 06:34 AM
  • Mirenia
    Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
    by Mirenia
    I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
    I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
    In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
    The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
    03-30-2025, 06:47 AM
  • orcic
    MASTER TL240 and new mainboard LW36BKC01
    by orcic
    I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
    The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
    After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
    Now I have some doubts about how to connect the new mainboard to the old power supply.
    First of...
    05-12-2023, 08:10 AM
  • Devonavar
    Vizio M43-C1 - How closely do I need to match the mainboard number?
    by Devonavar
    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
    So, I've ruled out the PSU for now.
    The reboot loop...
    08-14-2022, 08:46 PM
  • l0lhaxz1
    QN65QN90A - Mainboard MLCC failed - now bootloop
    by l0lhaxz1
    Hi
    I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
    Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
    Came to learn after a bit more research...
    02-06-2023, 08:59 AM
