Hp LA-D711P motherboard Schematics
  • kadi144
    • Aug 2015
    • 690
    • algerie
    HI all
    i need a hp 255 g5 bdl51 la-d711p rev3.0 shematics diagram
    thanks
  • kpavankumar
    • Sep 2019
    • india
    hp 255 g5 la-d711p schematic
    I need schematic of la-d711p
    Please help me sir
    • mferna14
      • Jun 2018
      • 1046
      Does any have the Schematics of this motherboard LA-D711P...I need this diagram if some one can help. Thanks
      • mferna14
        • Jun 2018
        • 1046
        Re: Hp LA-D711P motherboard Schematics
        Kindly help., anyone has this Schematics please., I just need it, I checked on the GPU VCORE coil I am only getting 0.29V, whereas the volts out here should be above 1volt., need to know what chip is producing the voltage for the GPU VCORE. Thank
        • Rupesh
          • Aug 2013
          • 13
          • India
          Re: hp 255 g5 schematic
          i want also schematic for la-d711p rev 1.0
          • Ns77510008
            • Mar 2020
            • 51
            • Moldova
            Hi guys. you need to know what kind of element
            burned out.
            La-d711p rev:3.0
            • Jozef11
              • Sep 2020
              • Slovensko
              Pd1-vc06c
              pd2-vc06c
              • Kartek
                • May 2020
                • 65
                • Türkiye
                Re: hp 255 g5 bdl51 la-d711p rev3.0
                bdl51 la-d711p rev 3.0 boardview V shematics diagram thanks
                • Wrightyzere
                  • Aug 2021
                  • 5
                  • Uk
                  bdl51 la-d711p rev 3.0 wiring diagram, schematics etc, needed if possible please guys.. appreciated :-) wanting to locate some more info on an ic located at pu2.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    PU2 is RT8243AZQW
                    • Wrightyzere
                      • Aug 2021
                      • 5
                      • Uk
                      PU2 is RT8243AZQW
                      Sorry for late reply but thx ✌️
                      • probabilite
                        • Aug 2016
                        • turkiye
                        what is the integrated code in pum2 thank you in advance
                        • probabilite
                          • Aug 2016
                          • turkiye
                          my motherboard is hp 15 BDL51 LA-D711P REV 1.0
                          • kurt Brown
                            • Jul 2015
                            • 3
                            • belize
                            VC064 is the number printed on this part... its a dual diode
                            • skynet83
                              • Feb 2021
                              • Россия
                              • skynet83
                                • Feb 2021
                                • Россия
                                This
                                  • 21845
                                  Originally posted by skynet83
                                  This
                                  AOZ1336DI
                                  • shabeel
                                    • Dec 2022
                                    • india
                                    la-d711p schematics.....?
                                    • VElektrik
                                      • Apr 2023
                                      • Россия
                                      Pd1 = pd2
                                      • fast@
                                        • Apr 2023
                                        • india
                                        LA-D711P schematics please
                                        • lemonsorlimes
                                          Dell G7 7500 (Motherboard P/N: 0VF32T) Schematics and BoardView
                                          by lemonsorlimes
                                          My laptop died on me about two years ago. I went through the basic recovery steps a few times and eventually, after plugging the battery back in for the xth time, a capacitor blew up on the board. Weirdly enough, the laptop then booted (battery removed) and has been running without issue ever since.
                                          I'd eventually like to examine the board in detail however I've had zero luck searching for schematics/boardviews for my particular motherboard.
                                          Any help would be greatly appreciated.
                                          Specs:
                                          MOTHERBOARD: HELA15_N18E_80W (P/N: VF32T 0VF32T CN-0VF32T)...
                                          06-17-2025, 04:51 PM
                                        • schematic_jack
                                          ASUS TUF B450-PLUS II motherboard schematics, or does this 60B SMD resistor even matter?
                                          by schematic_jack
                                          I think it would be dumb to toss a "modern" motherboard just because a resistor got scraped off, so here I am. I am hoping to find the right schematic so I can see if the motherboard can live without 1 of 3 60B SMDs in series likely scratched off by the backplate of a PCI-E card install or removal. It could be related to a functionality that is not needed or critical, or it could fry anything I plug into it and power on. If I could find a replacement, I could likely pop in on the board, but if I don't need to, then screw it, I don't mind leaving something dark that doesn't matter....
                                          07-06-2025, 02:00 PM
                                        • Username338
                                          Laptop BA92-09470B motherboard schematics
                                          by Username338
                                          Thank you for deciding to read this topic!
                                          Laptop: NP700Z3A-S02RU
                                          Motherboard: BA92-09470B
                                          I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                          I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                          03-09-2025, 03:52 PM
                                        • kadhim alhaddar
                                          Request: ASRock C3558D4I‑4L Motherboard Schematics
                                          by kadhim alhaddar
                                          Dear friends,
                                          I’m currently looking for the schematics of the ASRock C3558D4I‑4L motherboard. If anyone has a copy or knows where I can find it, I would really appreciate it if you could share it with me.
                                          Thanks in advance for your help!...
                                          07-18-2025, 11:03 AM
                                        • MajorErwin
                                          HP Chromebook x360, model : 14a-ca0057nf (Motherboard : DA00GIMB6H0 Rev : H) boardview or schematics needed
                                          by MajorErwin
                                          I need the schematics for the motherboard DA00GIMB6H0 Rev : H. It's a HP Chromebook x360. Thanks for your help.
                                          Have a nice day.
                                          Sincerely,
                                          ME
                                          06-09-2025, 02:40 AM
