Request: ASRock C3558D4I‑4L Motherboard Schematics
  • kadhim alhaddar
    • Jul 2025
    • Bahrain
    Dear friends,
    I’m currently looking for the schematics of the ASRock C3558D4I‑4L motherboard. If anyone has a copy or knows where I can find it, I would really appreciate it if you could share it with me.
    Thanks in advance for your help!
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
  • Felipe_Serra_83
    Request for v272un motherboard schematics (board for PC ASUS Vivo AIO)
    by Felipe_Serra_83
    Hello all. I'm currently checking this PC. I suspect a failure in the power source of EC chip. But without an schematic, I'm kinda groping in the dark. So, any help here would be much appreciated!
    Thanks in advance....
    07-09-2024, 04:32 PM
  • broke_boi
    Asrock B450 Pro4 motherboard won't power on.
    by broke_boi
    Hello all,
    (I am just getting into electronics repair so excuse the noobness )
    I have an Asrock B450 Pro 4 motherboard which doesn't power on. I have access to the Broadview file.
    I have checked that the PSU is working. I have the 5V standby on pin 9 and the 5V PSON# on pin 16. When I short the pin 16 and the ground I see the fan running and other voltages as well.
    I have removed everything from the motherboard except the CPU fan and have only connected the 24pin power from the PSU. I have not connected the 12V power from the PSU...
    09-09-2023, 09:21 PM
  • lemonsorlimes
    Dell G7 7500 (Motherboard P/N: 0VF32T) Schematics and BoardView
    by lemonsorlimes
    My laptop died on me about two years ago. I went through the basic recovery steps a few times and eventually, after plugging the battery back in for the xth time, a capacitor blew up on the board. Weirdly enough, the laptop then booted (battery removed) and has been running without issue ever since.
    I'd eventually like to examine the board in detail however I've had zero luck searching for schematics/boardviews for my particular motherboard.
    Any help would be greatly appreciated.
    Specs:
    MOTHERBOARD: HELA15_N18E_80W (P/N: VF32T 0VF32T CN-0VF32T)...
    06-17-2025, 04:51 PM
  • schematic_jack
    ASUS TUF B450-PLUS II motherboard schematics, or does this 60B SMD resistor even matter?
    by schematic_jack
    I think it would be dumb to toss a "modern" motherboard just because a resistor got scraped off, so here I am. I am hoping to find the right schematic so I can see if the motherboard can live without 1 of 3 60B SMDs in series likely scratched off by the backplate of a PCI-E card install or removal. It could be related to a functionality that is not needed or critical, or it could fry anything I plug into it and power on. If I could find a replacement, I could likely pop in on the board, but if I don't need to, then screw it, I don't mind leaving something dark that doesn't matter....
    07-06-2025, 02:00 PM
