IT8686E datasheet required
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Can anyone help me with the datsheet of IO CHIP IT8686E please.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: IT8686E datasheet required
    Not Available afaik.
    • vatecnica
      • May 2021
      • 42
      • Argentina
      does anyone know the diference with DXA, CXA and DXS?
      • noname2024
        • Aug 2024
        • 254
        • CỎ MỸ XỊN
        • SoulFreeze
          Help finding datasheet for component marked G34662
          by SoulFreeze
          Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
          Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
          Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
          05-01-2025, 03:56 AM
        • Rainbow_Chameleon
          Searching Datasheet for AM113 IC by O2MICRO
          by Rainbow_Chameleon
          I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
          Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
          If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
          On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
          So if anyone has a datasheet or at least...
          01-23-2025, 12:03 PM
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
        • evgental
          HP prodesk 400/600 G6 mini schematic/datasheet
          by evgental
          Hey everyone,
          I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
          Thanks a lot!
          08-04-2025, 04:58 PM
        • chth96
          Is there any datasheet for nichicon RT(M) series?
          by chth96
          A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
          https://www.badcaps.net/forum/troubl...e-been-blew-up
          and I finally fixed​ this retro game console by soldering varistor and glass fuse.
          But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
          I have spare console...
          11-28-2023, 03:36 AM
