YOGA 910 NM-A901 Schematic Request
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Hello, new member here. please be kind
    Basically i have dead yoga 910 no power wouldnt boot ....
    i need schematic to troubleshoot and to know what ic replacement should be purchased..
    if anyone out there have the schematic, and willing to share it here,
    I would appreciate it very much... thanks....
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: YOGA 910 NM-A901 Schematic Request
    • ss45
      • Jun 2019
      • 119
      • Brazil
      wow ! i didnt expect reply this fast... thank you so much !!..
      • alex@duocomputers.com
        • Oct 2020
        Does anyone got a board view file?
        • openminded
          • Apr 2017
          • 73
          • home
          from another post on the forum :
          https://www.badcaps.net/forum/showthread.php?t=86099
          • seppde
            • Jul 2022
            • 17
            I hope I act in order with the guidelines here
            I'm looking for the schematic of the right IO Panel of the Yoga 910 with the part number being NS-A902 for the following reason:
            I've got a defective Yoga 910 which I purchased cheaply and which supposedly only had a defective audio and USB-A Port. The Laptop internally is split in a left IO-Board with the charging connector, the mainboard itself and the right IO-Board with the USB-A Port and the Audio Plug.
            I figured I would just replace the right IO-Panel once I got the laptop. Since on receiving the laptop it wouldn't power on though, I did the usual - unplugging the battery, trying out different things and troubleshoot.
            Result:
            With the battery plugged in, no element of the right IO-Panel ever works, not even the power button. If the battery is unplugged, the power button and the usb port works as it should, even though the audio still remains off. If the battery is reinserted, the laptop powers up upon plugging in the charger and it remains on even if the charger is removed. So I believe that the battery is fine.
            I probed most of the voltages on the motherboard and some on the right IO-Panel with the help of the provided schematic already but couldn't fully understand the reason for the defect.
            My theory is that either some voltage is not provided or an enable signal is not reaching some IC.
            If someone could therefore provide me with the schematic of the right IO-Board it would be greatly appreciated. Any tips are welcomed as well.
            Have a good day
            Sepp
            • REpairAT
              • Nov 2020
              • 142
              • Austria
              I'm also looking for schematics of the left IO board, NS-A901 because two USB-C solder pads are ripped off.
              Thanks in advance!
              • alterr333
                • May 2019
                • 43
                • México
                Result:
                Have a good day
                Sepp
                There you go brother, full set. rio, lio mb and tvw
                use boardviewer last version to open tvw
                • alterr333
                  • May 2019
                  • 43
                  • México
                  Thanks in advance!
                  just uploaded it, check it out
                  • Ghost18_07
                    Zakaria
                    • Mar 2018
                    • 76
                    • Algeria
                    Thanks a lot>
                    • Doniciputat
                      • Aug 2022
                      • 109
                      • Indonesia
                      thanks ser
