Hi, i got to repair lenovo yoga 910 with mainboard nm-a901, found the isl9237 burnt, changed already 2 ic's, no 20v, only 5v. Can't find the reason. All resistor values seems fine.
Lenovo YOGA 910-13IKB No 20volts
Tags: None
Re: Lenovo YOGA 910-13IKB No 20volts
Make sure you have a good charger. 65w and above. Try the charger on another device that requires 20v and see if the charger handle it. I had similar no 20v issue and the charger was the main cause. -
Translate this it may help to understand the working condition of USB-C on this board,20V can`t be generated until all other conditions are met.
https://www.chinafix.com/thread-1201120-1-1.htmlLast edited by SMDFlea; 07-17-2020, 05:48 AM.Comment
I ordered a replacement chip, hope I will be able to replace it.
I was wondering if the chip is compatible with the ISL95857HRZ that is mentioned in the schematic?
I could not find datasheets, just compact ones that didn't contain proper info.
It's attached for convenience. Does anyone know if this is a common fault caused by something that can be improved?
I'm a complete beginner with reading schematics and understanding electronics and I am trying to learn so I'm very happy with that link, thanks.
MOD Edit: Link to schematic - https://www.badcaps.net/forum/showthread.php?t=81087
If anyone has a boardview version I would be very greatful too. thanks!Comment
Hi. See if the attached works for you.
MOD Edit: Boardview moved - https://www.badcaps.net/forum/showthread.php?t=83591
.Last edited by SMDFlea; 08-24-2023, 10:43 AM.Comment
hi, thanks a lot, works with the Tebo Viewer 4 from here : http://laptopserviz.bg/media/wysiwyg...T_view_4.0.zip
(even on Linux with Wine and mfc42.dll)
I'm waiting for my replacement PU4 chip, will post here if I have something constructive to addComment
thanks for all the help.
I replaced the isl9237 chip, which was a plain nightmare.
I am unsure if it is actually fully connected, especially for pin 17, because I thought I saw a broken line - I have no microscope and it's seriously hard with a magnifying glass.
I used : https://www.chinafix.com/thread-1201120-1-1.html and the boardview that is posted and the datasheet here for isl9237 to get the points:
https://www.renesas.com/eu/en/docume...9237-datasheet
As far as I understand it, it is indeed PQ10 not going on. It has 5.1 on the input but the gate, which seems to come from pin13 ASGATE.
I have no measurement on that pin with dc plugged in.
If I understand the chinafix link, that seems to be the cause for the pq10 not opening?
I am struggling because I am way of my league and the boardview is not as intuitive as openboardview based ones.
Can I test if this is the issue by injecting voltage after Pq10 and if so where and how much?
My VDD and ACIN (pin 18,17) seem to have only 4V, is that the cause of the issue?
I'm a bit stuck now, but perhaps this answers @galleria1313 's question?
Can anyone help me on how to proceed? thanks a lot!Comment
studied a bit further. It seems PQ10 does get 5.2 in and out, it was bad measurement I think. Again looking at the chinafix link, it seems VIN needs to be 3.3 V for the board to start at all, is that correct? And if that comes from pin 26 on PU4 there may be my issue.
Pin 26 is 0 and so is VIN for PQ19 . In my schematic I see U101, is that PQ16?
Unfortunately I don't understand it all well enough to know how to continue. I am happy to do measurements if anyone has suggestions. I thought about putting 3.3V on VIN and see what happens?
I don't understand the translation of the link well enough to understand the process completely...
oh, and my PR53 is about 0.52V, PR57 is about 5.2. As I understand it, PR53 should be 3.3V as the VIN for PQ19.
Would be great to get a confirmation that it's save to inject that and with how many amps.
any help and tips are appreciatedComment
I have also such a Notebook, which is completly death. The ISL9237 is also burnt, it's visible with the eyes.
I hoped I can change the ISL9237 and everything is ok. But what I read here, there are more problems... Has anyone find out more, what was the real reason??Comment
I too have this issue however shortly after the board quit completely, I found a board on eBay for a reasonable price that had a damaged inductor 1.5uh 16a Inductor I moved the inductor from my dead board 20v worked to the Windows login screen then started cycling rapidly 20 -> 5v -> 20v to which I responded by un-plugging the charger.
I thought maybe it was the USB C connector board... I ordered one. Same issue then shortly after it's permanently stuck on 5v.
What I find odd is that it will still attempt to charge at 5v powered on and will charge all the way if left powered off
I think it's the inductor however I'm tired of throwing money at this thing.
Will changing the inductor fix the issue, considering that the same issue moved from one board to another? And should I change the ISL9237 as well?- Where can I find information on PL12 (P/N: EM-15AM07V02-L1) I've searched but have no results I'm not sure what to replace it with.
- If I need to replace ISL9237 which one? https://www.mouser.com/c/semiconduct...ent/?q=ISL9237
i have question (just for sure)
Can i replace isl9237 with isl9238?
***EDIT> risked, replaced and all looks fine...20v output and chargingLast edited by CornholioGSM; 04-12-2025, 01:01 PM.Comment
This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:00 AM
This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-07-2024, 05:00 AM
This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...09-07-2024, 05:00 AM
- Loading...
- No more items.
