Re: Boardviews of some phones/tablets
This is a sticky topic.
Thanks for this.it looks good.Leave a comment:
i'm need schematics iphone XSM and 13 Promax 14Promax thanks verryLeave a comment:
thank you for your sharingLeave a comment:
Sadly, these standalone files for phones, as well as the original .pcb PADS files, were never of the highest quality. Tools such as ZXW often provide more accurate data and much more information. They are garbage cloud and subscription-based software, but that's how it is. Phoneboard has some stuff as well though, dunno how good (or bad) it is.
I'm a complete noob when it comes to boardviews and everything to do with electronics repairs, but I can tell that boardviews is a big PITA for everyone involved in repairs. Not only is lack of access a problem, it's also things like these, with incompatible and inconsistent file formats. I wish there was a common standard for boardview files that all technicians could use, be it BVR or BRD and what have you. Something like PDF, but for boardviews. Portable, cross-compatible, and open standard (since a few years back).
Manufacturers do not want these files to be released in the wild, and there is no point for them to have interoperability. Having a standard there is the least of their worry. And ours as well, we want the data first.
Some other aspects of board designs do have standards, such as the Gerber format for the PCB drawings, but that doesn't provide the same information as a boardview (although having Gerber files can be useful as well).
If it were up to me, I would pass a law that would make free access to boardviews mandatory, at a bare minimum. Accessible to everyone, or at very least repair professionals. Let me know if I'm wrong, but I think this is needed if we want a sustainable future where people can repair their tech gadgets rather than toss them out and keep on buying new, adding more to the e-waste basket.
It's the manufacturer's intellectual property and they consider it trade secret, no reason for them to provide any of this.
That's how it is, why do you think this job is difficult and some people try to fight for "right to repair"?
https://github.com/OpenBoardView/OpenBoardView/ has always been the official repository for OpenBoardView.
However, I published some of the decrypted files in BVR3 format here: https://www.badcaps.net/forum/showpo...&postcount=158 . It is possible to get the rest of them but it is a bit tedious.
As a side note, FZ format from Asus is also an encrypted format for example, but pafmaf reverse engineered the official viewer and extracted the key.
The similar CAE format from Asrock isn't supported since the encryption key hasn't been extracted.Leave a comment:
So "BVRE" files have "BVR3E001" in the header and "BVR" files have "BVRAW_FORMAT_1"?
Extension: .bvre
Magic: 42 56 52 33 45 30 30 31
Magic ASCII: BVR3E001
Extension: .bvr
Magic: 42 56 52 41 57 5F 46 4F 52 4D 41 54 5F 31
Magic ASCII: BVRAW_FORMAT_1
What is BVR2 header info? I'm just curious and I want to add it here for comparison and for posterity. I find this all very interesting, I'm more into this sort of stuff than electronics, to be honest. Thanks everyone for contributing to collective knowledge!Leave a comment:
Latest OpenBoardView release is 9.0.3. Pre-release is 9.90.0.
https://github.com/OpenBoardView/OpenBoardView/releasesLeave a comment:
These BVR files will work with Openboardview. They contain less information but still should help out a lot of people I hope.
Perhaps later Openboardview can support BGA pad names rather than just numbers, but it's a start.
Galaxy_S7.bvr iP6P.bvr iP7P_Qualcomm.bvr iPad_Mini.bvr
iP5.bvr iP6P_bvr.sqlite3 iP8P_Intel.bvr iPSE_820_00282.bvr
iP5C.bvr iP6S.bvr iP8_qualcomm.bvr iPSE.bvr
iP5S.bvr iP6SP.bvr iPad2.bvr
iP5S_WCDMA.bvr iP7.bvr iPad4.bvr
iP6.bvr iP7P_intel.bvr iPad_Air.bvr
Too bad I can't read those BVRE files with OpenBoardView, and I can't afford to pay for FlexBV for what is essentially a one man and one phone operation. I only need the boardview for Galaxy S7. I don't run a repair business, otherwise I would have purchased a license for your software, assuming I can source the needed boardview files on my own.
So you basically used FlexBV to convert the BVRE files to BVR files?
I can read BVR files in OpenBoardView. Including the "empty" iP7P_intel.bvr. It only shows an outline of the board and some odd looking transistors scattered around in two areas. I have checked all the BVR files in version 8.0.
Strangely, the iP8_qualcomm.bvr crashes the program, so that one can't open at all.
The iPad_Air.bvr has some odd looking outline and missing or misplaced filler lines for texture at certain places, and a set of resistors and capacitors (R1096, C1096, R1097, C1097) hanging out outside the board.
The iPad2.bvr looks really bad. The outline is a triangle and a trapezoid. The T1378 for example takes up half the board.
With iPad4.bvr we have overlapping components like J7500 and R8296 which is huge, again, taking up half the board. The outline is missing on one end.
The iPSE.bvr and the iPSE_820_00282.bvr are binary identical. I did not look for visual differences. Both will open and look correct to me and my untrained eyes.
I am documenting these things for others to observe and be aware of. I do wonder though if these issues exist in the BVRE versions of these files? I don't have FlexBV so I can't check. These issues may have existed in the original files and were not introduced by conversion. That, I do not know.
Previously most boards only required schematics to assist with repairs, the parts were labelled on the PCB silkscreen and the board was the literal boardview. Over time with increasing part densities silk screening became impractical and now frequently non-existent on devices such as Macbook and iPhone boards.
https://pldaniels.com/flexbv/
If it were up to me, I would pass a law that would make free access to boardviews mandatory, at a bare minimum. Accessible to everyone, or at very least repair professionals. Let me know if I'm wrong, but I think this is needed if we want a sustainable future where people can repair their tech gadgets rather than toss them out and keep on buying new, adding more to the e-waste basket.Leave a comment:
BVR (Boardview Raw) was actually originally spawned when a dump from the Microsoft Access DB "BV" format was being used for some boards, hence BVR = BV 'Raw'.
After BVR for the BV, the initiative was taken to make BVR2 and subsequently BVR3 so that some less frequently encountered boardview formats could be exported in to a more open/verbose format.
BVR3 is supported in the latest OpenBoardview.
BVRe is an encrypted version though anything that was in BVRe should be available as BVR these days.
OpenBoardview cannot utilise all the information that BVR3 stores but it can still read everything it requires ( things like pad outlines, part outlines and some other attributes ).
No documentation currently available though a text editor opening up a BVR3 does tend to walk you through it.
It's an verbose and data-reduntant format, intentionally so.Leave a comment:
by paparazzo79Hi guys.I needed charger for my phone but could not find original one which is blackview 6600 pro.
I purchased the chinese one same specs but none of the cables is included.
So does it matter when charging the phone over that charger what cable do I use (micro usb or type c)?
I'd need to use type C, I suppose I can use type C because none ofthe cables is included. -
by psyco744Dear forum members, I wanted to share with you an alternative free program where you can find some schematics related to mobile phones and tablet. I hope it will be of use to you.
Code:İphone 4 İphone 5 İphone 5c İphone 5s İphone 6 İphone 6s İphone 6s plus İphone 7 (intel) İphone 7(qualcom) İphone 8 (intel) İphone 8 (qualcom) İphone 8 Plus İphone 8 İphone X (baseband and qualcom) İphone xr İphone xs
Channel: Schematic Requests ONLY!
04-24-2022, 03:08 PM -
by piernovActivity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
Reminder about the rules and the organization of the "Troubleshooting Laptops, Tablets, and Mobile Devices" section.
This section and its subsections are about the following classes of devices:- Laptops
- Phones
- Tablets
- Other mobile devices
by AJ847.63eHi All,
Has anyone tried to use a XS screen on a iphone X before? I've got a old dead iPhone XS which I was hoping to use the screen on my iphone X as the glass on it has cracked. According to google the connectors are the same but some screw holes don't line up, but I'm assuming that doesn't matter as I can use some double-sided adhesive instead. Better than spending 280 bucks on a new screen when I already have a perfectly good OEM XS one.07-31-2023, 10:31 PM -
Apple iPhone 6 820-3675 Plus Schematic & Board View
iPhone 6+...-
Channel: Schematics and Boardviews
10-03-2024, 08:21 AM -
- Loading...
