hp 14 0p Quanta 0P1
  • menshawy
    • Aug 2013
    • 400
    • egypt
    hp 14 0p Quanta 0P1
    Hi
    i need HP HP 14-bs000 Boardview
    MB DA00P1MB6D0
    Please help
    thanks
  • peste
    • Dec 2016
    • 12973
    • ROMANIA
    Re: hp 14 0p Quanta 0P1
    https://www.badcaps.net/forum/showthread.php?t=66810
    • menshawy
      • Aug 2013
      • 400
      • egypt
      thank you
      but this for Quanta G34A DAG34AMB6D0
      i need DA00P1MB6D0
        • 21216
        This one https://www.badcaps.net/forum/showthread.php?t=74740
        • menshawy
          • Aug 2013
          • 400
          • egypt
          Originally posted by SMDFlea
          thanks my friend
            • 21216
            You should thank @on/off for posting it .
            • menshawy
              • Aug 2013
              • 400
              • egypt
              you are right
              • M4n0l0307
                • Nov 2020
                • 167
                • Colombia
                Thank you !
                • reformatt
                  • Feb 2020
                  • 1419
                  Anyone have the boardview for the OP1 board? The links here are for OP1B, which has 2 DIMM slots. The board I have is DA00P1MB6D0 Rev D (OP1) with a single DIMM slot.
                  Trying to get data off the eMMC chip, just need to know where the data lines are on the board. CPU is shot after a beer spill.
                  • reformatt
                    • Feb 2020
                    • 1419
                    Found the correct boardview for OP1, attaching it here with schematic for future reference.
                    Will post details if I'm successful in dumping off the eMMC via SD Card reader.
                    • ruletero
                      • Nov 2018
                      • 182
                      • Mexico
                      Thank you friend
                      • jacknick
                        • Aug 2020
                        • 14
                        • Chile
                        Many thanks for this.
                        • kazttiyo
                          • Jun 2015
                          • 11
                          • Chiapas
                          Thank you...
                          • kazttiyo
                            • Jun 2015
                            • 11
                            • Chiapas
                            Thank you...
                            • NikhilSimon
                              • Dec 2021
                              • 25
                              • india
                              Not the same
                                • 21216
                                Originally posted by NikhilSimon
                                Not the same
                                Read the whole thread, especially posts 9 and 10
                                • sonunigam
                                  Quanta G34A Big Trouble
                                  by sonunigam
                                  Hey Guys,
                                  I'm facing a very mysterious Problem, I've got a Motherboard Quanta G34A Which cannot be turned on with charger but it can be turned on with battery. when i connect a faulty but Original battery Laptop Turned on with charger. I've checked all Charging IC PU1 (ISL88750) Voltages, Everything is perfect but when i checked 3/5V Coils there is no voltages. I've checked VIN voltages on PU2 (SY8208B) for 3V IC that is only 8,7 VOlts. So i think VIN is not generating properly. I think VIN should be 19V. Anybody can give me any idea what should i do? I'm uploading Schematic Diagram n BoardView....
                                  06-21-2023, 08:17 AM
                                • lpraderi
                                  Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                  by lpraderi
                                  Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                  In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                  Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                  at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                  Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                  11-25-2023, 09:31 AM
                                  Quanta G34A G35A DAG35AMB8E0 DAG34AMB6D0 Rev:D :E Bios
                                  by SMDFlea
                                  All these Bios are for different models with the DAG35AMB8E0 DAG34AMB6D0 Rev: D and E Motherboard.
                                  EDIT: Another motherboard to add to the list: DAG38DMBCC0 REV:C 17-w273nr BID08217
                                  EDIT: Another motherboard to add to the list: DAG35DMBAD0 REV: D
                                  Bios for Discrete and UMA .
                                  DAG35AMB8E0 REV:E 15-ax002tx 15-ax015TX 15-bc007nc
                                  Omen 15-ax***** BID: 0820D, 08209 ,08217
                                  DAG35AMB8E0 Rev: D 15-au*****
                                  15-BC001NT 0820D .DMI 6AC000 - 6AE0FF KEY 278000 - 27803F
                                  Check your BID number and CPU ID ....
                                  11-06-2018, 09:12 AM
                                • Francisco.s
                                  Quanta N76 power-on issue.
                                  by Francisco.s
                                  Hello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
                                  I only get 3.3V, 5V, and 1.05V; no other voltages.
                                  I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
                                  The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
                                  I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...
                                  07-14-2025, 02:20 PM
                                • mahmoodjavan
                                  Quanta 0P1 DA00P1MB6D0
                                  by mahmoodjavan
                                  HP 14-bs000ur
                                  Celeron N3060
                                  Bios W25Q64FVSIQ...
                                  08-14-2019, 06:22 AM
