820-01521 schematic
  • rascao
    • Jul 2020
    • 51
    • España
    #121
    Thanks bro
    • Muensteraner
      • Oct 2023
      • 5
      • Moldova
      #122
      Thank you very much!
      • carimbenzema
        • Jul 2024
        • 7
        • Cameroon
        #123
        Thanks guys for your work
        • datarus
          • May 2021
          • 7
          • Sweden
          #124
          Originally posted by pyry
          MacBook Air A1932 disfrutenlo colegas
          Thank you so much
          • Ammalik1122
            • Aug 2024
            • 3
            • INDIA
            #125
            820-01521 schematic​ need
            • Lisa Jennifer
              • Nov 2023
              • 7
              • Mauritius
              #126
              Thanks you Very much.
              • Lisa Jennifer
                • Nov 2023
                • 7
                • Mauritius
                #127
                Thanks very much.
                • danro
                  • Aug 2011
                  • 52
                  • Serbia
                  #128
                  Thank you!
                  • astroboypaul
                    MacBook Air A1932 Keyboard Schematic 820-01294-A
                    by astroboypaul
                    Can anyone help with a schematic and board layout for the keyboard 820-01294-A in Macbook Air A1932 please? (for reference, mainboard is 820-01521-A)
                    Alternatively, I'd settle for confirming value of a resistor on the keyboard (red arrow in picture below)
                    Water damage keyboard, with corrosion visible on the noted resistor (picture was taken after cleaning). One pad under the resistor was corroded and resistor fell off while clearing the potting resin (or whatever it is Apple has coated the components in).
                    By chance I discovered that mainboard 820-02443 has...
                    03-22-2024, 11:57 PM
                    Apple MacBook Air Retina A1932 820-01521 Schematic & Board View
                    Apple MacBook Air Retina A1932 820-01521 Schematic & Board View...
                    10-03-2024, 04:25 AM
                  • bouch
                    unlock macbook air A1932 2019
                    by bouch
                    hi
                    i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                    i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                    i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                    have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                    I need help or information?
                    Does anyone have the minat2 activator 1.4 software?
                    Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                    Thank yo...
                    03-12-2025, 10:14 AM
                  • spwoof
                    Seeking LCD Schematic for MacBook Pro M1 A2485 - Aiming to Repair, Not Replace
                    by spwoof
                    I'm currently working on a MacBook Pro A2485 and have encountered an issue with the LCD. Instead of opting for a full replacement, I'm interested in performing an in-depth repair on the LCD itself. I'm hoping to find the schematic for the LCD in order to understand its architecture and troubleshoot more effectively.
                    If anyone has access to the schematic or can point me in the right direction, I'd really appreciate it. My goal is to repair the components and connections within the display, rather than going for a costly replacement. I've been in the notebook...
                    10-05-2024, 08:02 AM
                  • spwoof
                    by spwoof
                    10-05-2024, 07:24 AM
