Asus N551J
  • amatic
    • Oct 2016
    • 12
    • Croatia
    Asus N551J
    I have Asus N551J with no power. I need shematic please.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Asus N551J
    no schematic, only boardview
    what is the motherboard revision number ?
    • amatic
      • Oct 2016
      • 12
      • Croatia
      Re: Asus N551J
      Rev 2.0
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Re: Asus N551J
        first check for +19V near the Dc connector 6pin you have 2 FETS and the current sense resistor test the voltage on 2 FETS 4 pin voltage & current sense resistor
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Re: Asus N551J
          Originally posted by amatic
          Rev 2.0
          This is rev 2.0
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • ShadowAi
            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
            by ShadowAi
            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
            03-15-2024, 10:46 AM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
