i find the reference mosfet - UX31E Schematic
  • maha2005
    • Oct 2013
    • 20
    • tunisia
    hi plz i need reference for these mosfet
    ( n channel or P channel)
    motherboard Asus reference
    UX31E main board rev 3.2
    • 20873
    Re: i find the reference mosfet
    What are the part numbers on top of the mosfets
    • maha2005
      • Oct 2013
      • 20
      • tunisia
      have u the schematic ?
      thanks
      • maha2005
        • Oct 2013
        • 20
        • tunisia
        thanks
          • 20873
          No i don`t. I can`t find one for free, so unless someone else uploads one you`ll have to pay . ********************************
          • piernov
            • Jan 2016
            • 4435
            • France
            Use UX31A2 schematics. Boardview of UX31E available at sualaptop365.
            • maha2005
              • Oct 2013
              • 20
              • tunisia
              how i can open this file .fz
              • piernov
                • Jan 2016
                • 4435
                • France
                Use OpenBoardView with FZ key (you can grab it from the IRC channel topic) or use PCBRepairTool (which is a pain to use).
                • dj8452000
                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                  by dj8452000
                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                  02-18-2025, 08:28 AM
                • tmaster21
                  Ideapad 100 NM-A841, P channel mosfet on laptop in.
                  by tmaster21
                  Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
                  Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
                  07-17-2023, 09:48 AM
                • Blastsail
                  Help find compatible MOSFET from Asus FA506 DABXBMBAD0
                  by Blastsail
                  I have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
                  I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated....
                  05-07-2022, 07:35 AM
                • Oliver111
                  Asus UX535L.Help to find name of mosfet driver
                  by Oliver111
                  Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
                  04-08-2024, 07:47 AM
                • eccerr0r
                  old X58 triple channel board... memtest86 memory speed?
                  by eccerr0r
                  Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                  Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                  Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                  06-28-2025, 09:06 AM
