ASUS G750HJ Wont power on schematics needed
  • thuttu77
    • Apr 2015
    • 35
    • Finland
    Does anyone have layout files and or chematics to Asus G750HJ
    My G750 wont power up and power wont come even to fuse nearest DC plug so my assumption is that there is something wrong in control of 2 fets or fets it self but it would be interesting to see how they are connected and what is the prupose of 3rd pin of DC plug
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Re: ASUS G750HJ Wont power on schematics needed
    This is boardview for similar model but the 19v rail is the same...
    So you have no voltage when charger plugged? are you sure it is not shorted? is it shorting charger?
    • thuttu77
      • Apr 2015
      • 35
      • Finland
      Yeah MB is propably same and it differs on other things like GFX or so
      I did already look at it thx.
      Well I can see 19V before fets but not after so I need to do some measurements from 19V line andtry to check if charge monitor chip isnt workin or fets are faulty.
      Problem did begin in battery did stop charging time to time until it died fully atleast old owner said so.
      • nassimhamdi
        • Feb 2016
        • 149
        • algeria
        Thank you
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • ShadowAi
          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
          by ShadowAi
          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
          03-15-2024, 10:46 AM
        • meraklinetx
          Asus Z97-a power cycle, no boot no cpu voltage
          by meraklinetx
          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
          05-10-2023, 06:08 AM
