Need schematic MSI MS-16Y1
  • dylen
    • May 2017
    • 173
    • Mauritius
    Hi everybody, can someone send me the schematic of MSI MS-16Y1.
    The laptop works fine on external display via VGA & HDMI but not on onboard lcd. Ive check on the mobo, seen 3.3v on pin 2,3 and 19v on last pin.Change lcd & cable with same result.At times on power on display flashes for 2 seconds on lcd then blackout, but works on external display always.
  • dylen
    • May 2017
    • 173
    • Mauritius
    Re: Need schematic MSI MS-16Y1
    Forgot to mention that the video is uma not discreet.
    • eurowill
      a2141 820-01700 internal display not working / external works
      by eurowill
      Hey ya'll this is my first post on here. I recently aquired a used/broken 2019 mbp 16 a2141 with the 820-01700 board. Seller told me that the laptop needed a new lcd. However upon doing some troubleshooting i found out the lcd is fine.
      Laptop boots like a normal, plays chime, touchbar lights up however there is no image on the internal lcd. If i connect and external monitor while its already on, nothing happens and no image is displayed on external. However if i restart or boot the machine while its plugged in, the external then works and a backlight is now visible on the laptop....
      07-23-2024, 10:06 AM
    • amuse619
      Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
      by amuse619
      Hello!
      Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
      Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
      08-14-2024, 01:22 PM
    • DqMagetz
      Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
      by DqMagetz
      Good day!
      I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
      Here are the voltage readings:
      • Input – 19V (stable)
      • +LCDVDD – 3.3V briefly, then drops to 0V
      • EDP_HPD – 3.3V briefly, then drops to 0V
      • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
      • EC BKOFF# – 1.8V briefly, then drops to 0V
      • PANEL_OD_EN – 0.3V
      Is it possible that the EC chip is corrupted or damag...
      07-12-2025, 09:37 PM
    • baglaivlad
      A1534 2015 820-00045 internal display not detected, but external works
      by baglaivlad
      Hi everyone!
      Trying to repair A1534 2015 macbook. The keyboard and touchpad was liquid damaged by coke, but the MLB has no signs of corrosion. The laptop successfully turned on, but missed a display flex. Replaced keyboard, touchpad and display flex, but still no image on the internal display (no backlight as well). When connecting to the external display the laptop works just fine (I have an image).
      It seems like internal display is not recognized. I tried multiple known-good displays and display flexes, the outcome is the same: no life on the display.
      It lead me to believe...
      06-08-2024, 02:30 PM
    • Ado02
      MacBook Pro A2159 - No Display / Works on External Screen
      by Ado02
      I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
      Please see the attached image.
      I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
      Can anyone suggest where to go from here?...
      01-12-2023, 03:35 AM
