Asus K53SV 3.0 main board need references
  • TheQuentincc
    • Mar 2017
    • 64
    • France
    Hi, I have a asus K53SV 3.0 main board and I have the BQ24740 not working (there is a hole in the chip) and a double diode (I presume this is that) which start by "2W" and I don't what is it exactly, so I'm coming here to ask you if somebody that have the schematics or something can give me the reference of this double diode please.
    Here the picture of it :
    Thanks for all
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: Asus K53SV 3.0 main board need references
    This is boardview for your board
    • TheQuentincc
      • Mar 2017
      • 64
      • France
      Thanks, but what soft do I need to use it?
      • piernov
        • Jan 2016
        • 4439
        • France
        OpenBoardView can open it if you grab the key on the IRC channel. Otherwise you can use PCBRepairTool.
        • piernov
          • Jan 2016
          • 4439
          • France
          The BoardView is not gonna help you though.
          Here someone had the same issue: https://www.elvikom.pl/asus-k53s-dead-t37809.html
          PQ8804 = PMBT2907A = W2F marking code.
          • TheQuentincc
            • Mar 2017
            • 64
            • France
            merci
            • Andyservo
              • Jun 2013
              • 152
              • Indonesia
              thanks for bdv..
              • beal
                • Jul 2017
                • 122
                • IR
                very thanks
                • BlackSkullDragon
                  • Jan 2019
                  • Polska
                  Thanks for boardview
                  • hunter1
                    • Mar 2020
                    • tunisia
                    thank you for boardview
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • JDC
                      by JDC
                      ONN 100012588
                      Long answer:
                      07-15-2022, 07:39 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
