HP 17-e040us 3.3v at power switch no boot. Schematic?
  • Doc38343
    • Apr 2015
    • 402
    HP 17-e040us 3.3v at power switch no fan and will not boot.
    Anybody got a Schematic?
    The 3.3v pulls down on pin 3 but I can't trace it any further... all caps in the zone are good. No apparent corrosion or liquid damage.
    I found a couple of questionable sights selling so called schematics but after review i do not trust those places.
    Thanks for any incite. This lady can't afford a MB so i'm trying to see if it is even salvageable.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP 17-e040us 3.3v at power switch no boot. Schematic?
    Make sure you use the correct power adapter.
    Check for 3.3V/5V at PL22/PL24.
    You could try to backup&flash both SPI ROM.
    Schematics attached.
    • Doc38343
      • Apr 2015
      • 402
      Thank you very much, I REALLY appreciate the input and the schematic!
      I am on hold right now my customer has informed me she will be buying a new laptop and only wants me to transfer her data. They usually allow me to keep the old system in lieu of a discount so if she does i want to do board level repairs. I will re-post if and when i start back on this one.
      Very appreciative to all you guys!
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Powderfanupnorf
        Dell AL440LX power on switch circuit help required
        by Powderfanupnorf
        Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
        So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
        My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
        06-24-2024, 01:24 PM
      • grimacelord
        NEC TurboExpress On/Off Power Switch Replacement Help
        by grimacelord
        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
        11-09-2023, 09:49 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • dicky96
        Bang & Olufsen (HP) Omen Laptop power light flashes once but no boot
        by dicky96
        Hi guys
        I have a B&O Omen laptop here. It has very specific fault symptoms, hopefully someone can give me some guidance
        If I plug in a known good 180W third party charger the little LED next to the power jack on the laptop flashes red once, but the laptop will not start. It will not flash red again unless you unplug and reconnect the power.
        If I remove the main battery (I can't see a cmos battery) then the led by the jack does not flash when I plug in the adapter, but if I press the power on button with adapter attached it flashes once white every time...
        03-24-2023, 06:33 AM
