Asus N55SL total dead
  • aanan
    • Dec 2010
    • 222
    • India
    Asus N55SL[da0nj5mb8c0 rev:c]
    total dead fan spin no display i need schematic & board view.
  • aanan
    • Dec 2010
    • 222
    • India
    Re: Asus N55SL total dead
    anyone please.
    • aanan
      • Dec 2010
      • 222
      • India
      Please help Thanks
      • kotnatan
        Banned
        • Apr 2014
        • 181
        • Ukraine
        i have only BoardView
        What is written on the sticker ?
        60-xxxxxx -?
        • aanan
          • Dec 2010
          • 222
          • India
          Thanks for reply
          Written on ram slot sticker 60-N1oMB1300
          • aanan
            • Dec 2010
            • 222
            • India
            Hallo kotanatan iam waiting.
            • kotnatan
              Banned
              • Apr 2014
              • 181
              • Ukraine
              i have only
              ASUS N55SL - Repair Guide
              BoardView (.FZ) ------->
              60-NF5MB3600-B03
              60-NF5MB3100-A01
              60-N5FIO2000-C01
              60-N5FAU1000-C01
              • aanan
                • Dec 2010
                • 222
                • India
                Thanks for reply.
                • highpulse
                  i hate HP
                  • May 2013
                  • 1489
                  • portugal
                  kotnatan , possible to share the boardview and rep guide you got ?
                  • Stevie2001
                    • Apr 2018
                    • 183
                    • irland
                    Display cable pin test if u hv 3v on pin
                      • 21853
                      Look at the dates stevie ,2016 !
                      • tranquility
                        Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
                        by tranquility
                        hallo,
                        i have an asus X515KA-EJ058W here.
                        just both leds white...he battery blinking without battery connected
                        consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
                        if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
                        power on again is possible but again 400mA then and no picture.
                        now the really strange
                        i flashed bios (some version i found on the internet) and resoldered....sometimes...
                        12-11-2024, 06:47 AM
                      • ShadowAi
                        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                        by ShadowAi
                        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                        03-15-2024, 10:46 AM
                      • hdd00
                        Asus TP412UA DEAD
                        by hdd00
                        HI all. I have here 2 identical asus laptops ,TP412UA, that are dead(probable cause , one of the ac adapters is bad). No power up on ac adapter or battery, no sign on life when adapter is pluged in, no response from power button, nothing.
                        Taking as reference the measurements from this post
                        https://www.badcaps.net/forum/troubl...g-on#post82907
                        I don't have any short on any coil, but, without battery, when I give 19v on dc jack, the consumption...
                        08-14-2024, 02:14 AM
                      • iusar
                        Asus PRIME B460M-A R2.0 - Absolutely Dead Board
                        by iusar
                        Hello.
                        I'm working on an Asus PRIME B460M-A R2.0 that's completely dead. The Nuvoton NCT6798D Super I/O gets abnormally warm in standby.
                        Need this boardview to measure Super I/O signals. Much appreciated!
                        06-23-2025, 07:51 PM
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
