[help] np-q45 schematic
  • phantomEVO
    • Mar 2013
    • 488
    hi to all, i'm serching for np-q45 schematic, because i've lost those two tiny components and i don't know how to replace them
  • khaahk
    • Dec 2013
    • 748
    • Estonia
    Re: [help] np-q45 missed component
    This might be it:
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      this might be help you
      https://drive.google.com/folderview?...mM&usp=sharing
      • phantomEVO
        • Mar 2013
        • 488
        awesome help! so c840 and c842 are 100nF
        could you help me to find on others boards the same component?
        i've a DA0ZG5MB8G0
        a la-3491p
        and a k52n
        • phantomEVO
          • Mar 2013
          • 488
          i've found the da0z diagram
          http://tehnodoc.com/files/schemes-fo...zg5mb8f0-zg5-/
          is it correct to solder from this board the component c540? for example?
          it's 0.1u that i think it's equal to the 100f component on q45 right?
          • khaahk
            • Dec 2013
            • 748
            • Estonia
            yes 0.1uF = 100nF
            Voltage tolerance is ok also: 6v original vs. 10V substitute.
            • phantomEVO
              • Mar 2013
              • 488
              thanks
              • chth96
                Is it possible bridging tiny broken trace
                by chth96
                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                cutting tiny trace.
                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                12-03-2022, 11:32 PM
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • atunguyd
                Acer x163w Monitor PSU schematic
                by atunguyd
                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                03-05-2025, 02:08 PM
              • ianpoultonknights
                Zenbook Flip 15 UX562AI schematic
                by ianpoultonknights
                Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                06-26-2025, 02:41 PM
              • Much Bugs
                MSI Z390 A-PRO Schematic and BoardView
                by Much Bugs
                The Schematic and BoardView( *.cad ) of MSI Z390 A-PRO , the board model no is MS-7B98 Rev1.0-1.1 ....
                06-24-2025, 10:13 AM
