I need troubleshooting assistance with provided schematic
  • Agent24
    I see dead caps
    • Oct 2007
    • 5069
    • New Zealand
    Re: I need troubleshooting assistance with provided schematic
    Originally posted by atsio
    EC controller (here called LPC) is U4 - W83627EHF
    Oops! It is? Datasheet for that chip says nothing about EC, just super I/O controller.
    Now I realise this is a desktop board - posted in the laptop section - do desktop boards even have an EC? I don't think they need one?
    -David VanHorn
    • atsio
      • Oct 2013
      • 819
      • Greece
      From ISL6566 datasheet:
      " VID4, VID3, VID2, VID1, VID0, and VID12.5
      These are the inputs for the internal DAC that provides the
      reference voltage for output regulation. These pins respond to
      TTL logic thresholds. The ISL6566 decodes the VID inputs to
      establish the output voltage; see VID Tables for
      correspondence between DAC codes and output voltage
      settings. These pins are internally pulled high, to
      approximately 1.2V, by 40μA (typically) internal current
      sources; the internal pull-up current decreases to 0 as the VID
      voltage approaches the internal pull-up voltage. All VID pins
      are compatible with external pull-up voltages not exceeding
      the IC's bias voltage (VCC)"
      So replace U1 again
      • rookieme
        • Oct 2014
        • 399
        • Greece
        Thank you again, I'll keep you informed as soon as I replaced it again.
        • rookieme
          • Oct 2014
          • 399
          • Greece
          I swapped the U1 from the working board with no luck [low voltage again].
          The other board works fine with the U1 from the non working one.
          As I can see U1 works ok but the voltage is regulated according the VID0-4 pins.
          I get the correct voltage for the VID signals I get.
          So it is the VID signals that set the voltage.
          U4 could be the resposible for the VID signals?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5069
            • New Zealand
            Could be, or it's doing something to change them incorrectly. I don't know exactly how the circuit works. The datasheet I found doesn't say anything about how the VID pins work except it can read and write to them - so I guess it's maybe possible that it can change them, and override what the CPU says.
            atsio said U4 was the only other place the VID signals went, so if U1 is OK then I agree it makes sense to look at U4 next.
            -David VanHorn
            • rookieme
              • Oct 2014
              • 399
              • Greece
              #26
              I swapped U4 and the working one continues to work.
              The faulty one continues the problem with cpu undervoltage.
              So what tells U4 what signals to produce?
              • atsio
                • Oct 2013
                • 819
                • Greece
                #27
                If i were you I would replace and Q16,Q17 and Q18
                And consider and the other 8 fets on the other two phases
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3627
                  • slovakia
                  #28
                  reflow cpu socket.
                  • rookieme
                    • Oct 2014
                    • 399
                    • Greece
                    #29
                    Well, new info for the issue.
                    At the working one, if I remove the bios [removable] I get the same "fault".
                    So I presume that the low voltage is regular operation [like safe mode], set by cpu if something else doesn't work as it should.
                    So I have a fault somewhere that prevents the normal operation of the cpu and then cpu signals for low core voltage - that makes some sense.
                    All I have now to find the fault, many components to try but will start from the basic ones [NB, SB]
                    I'll keep cpu socket reflow for the end....
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3627
                      • slovakia
                      #30
                      id signals comes from cpu through socket. have one dv6000 with low voltage. after reflow socket it work ok
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5069
                        • New Zealand
                        #31
                        Dumb question I know, but I suppose you already checked for corrupt BIOS then?
                        -David VanHorn
                        • rookieme
                          • Oct 2014
                          • 399
                          • Greece
                          #32
                          Not dump at all, from the working one if I remove the bios I get the same failure. Yes I did made a swap as they are removable.
                          The fault has been found finally as it worked after reballing the NB.
                          As I mentioned the low core voltage was the result of an other issue.
                          Thank you all for your time and effort.
                          • ShadowAi
                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                            by ShadowAi
                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                            03-15-2024, 10:46 AM
                          • diamon
                            Dell Latitude 5520 completely dead
                            by diamon
                            I have bought a not complete and defective Dell Latitude 5520 for parts (needed the networkconnector (RJ45) to repair a other board).
                            Have repaired the other board (Dell Latitude 5540) and I wanted to know if I could find out what is wrong with the 5520 board (SouthPeak15 TGL MB 8L 19819-1) and perhaps repair this one also.
                            After connecting the USB-C charger (both USB-C ports on the laptop, does not have an other option) and pressing the power button, nothing happens (no lights or fans, no capslock).
                            Have checked with a thermal camera, and there are a couple of things...
                            03-05-2025, 02:23 PM
                          • reessi
                            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                            by reessi
                            Hello:
                            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                            I started on the ACER:
                            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                            10-29-2024, 11:31 AM
                          • Gau_saha
                            Troubleshooting samsung syncmaster 2333 BN44-00297A schematic
                            by Gau_saha
                            Sir,
                            Do anybody have IP4L23D CODE BN44-00297A schematic of samsung monitor ? I need the schematic .Please share with me if anybody have it.
                            Thanks.
                            i
                            10-04-2023, 04:47 AM
                          • sarry86
                            Help me troubleshoot Hp Pavillion 15 DAG74AMB8D0 REV D Power
                            by sarry86
                            As usual please guys go easy on me 🥶, I have this mentioned laptop that was once working but with display problem, my friend took it to an inexperienced technician (like me 🤒) and they got it completely dead, now he has brought it back to me and gave me for spare parts. Although I am not an experienced technician, initial troubleshooting suggests that the pc has the sign of life as it hasn't been shorted anywhere (visual inspection) nothing is heating up and all the voltages prior to the main power rails are available (according to the schematic) it is just some area where it seems the voltages...
                            01-28-2024, 05:46 AM
