help with the dell 14z Schematic please
  • Blacktek
    • Nov 2014
    • 250
    winston dmb40 intel mb rev0.0 schema
  • Blacktek
    • Nov 2014
    • 250
    Re: help with the dell 14z please
    anyone?
    • ~MM~
      • Feb 2018
      • 6
      Just incase someone is searching and this thread pops up... Currently seeking boardview, not schem.
      • Atibooks
        sisbytes
        • Jun 2017
        • 13
        • Brasil
        Re: help with the dell 14z Schematic please
        thanks
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
