for comparison I used a schematic acer quanta zhg because both use the IC OZ8380aln.
on pin 9 LX2 measured resistance 13ohm, while the pin 16 LX1 146ohm. for a processor that can not be removed like this netbook, how should the coil resistance ?. This direction towards NBcore
before reflow motherboard I want to make sure nothing is short
before reflow, I think and analyze again.
try to power netbooks, touch the cpu and chipset and feels warm, meaning the cpu and chipset are already working.
during the search for the schematic, accidentally discovered this tread https://www.badcaps.net/forum/showthread.php?t=41172. I finally decided to once again flash the BIOS with the file. and it worked.
Hi, I think I have the same problem, may I know how you flashed the bios? Anyway to do on the board or I need to unsolder and flash from computer, I have the following flasher, but I've not used it, I will research now online:
CH341A 24 25 Series EEPROM Flash BIOS DVD USB Programmer
I got it a while ago but never tried it. I have all the equipment to unsolder it.
