Has anyone have schematics and board views for Apple Logic board # 820-00239-09? Thanks!
MacBook Pro 2016 non Touch Bar 820-00239-09 schematics and board views
Assuming...7 Photos -
by HaukeHi, I am asking for a little troubleshooting advice.
The laptop seems to boot up fine. Caps lock is working, the touch pad has haptic feedback, and even the "charger plugged"-sound is present.
Power consumption is about 15-30W at boot and idles at about 20W.
Unfortunately, the display and the touch bar are completely black (No signal and no backlight).
I don't get a signal on an external USB-C display either. Also not in safe mode.
I noticed that only the left fan (from the bottom side, hinge on top) seems to spin up. I think... -
Apple MacBook Pro 13" Touch A1989 820-00850-A Schematic & Board View...
Channel: Schematics and Boardviews
by RezendesHello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...-
Channel: Schematic Requests ONLY!
by tony359Good day all,
I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
Once the fan was swapped, I installed an OS and it worked fine.
The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
If I see that right, I have missed VCORE on L7100 (page 59).... - Loading...
