mv-4 e89382 HannStar i need the board wiev file if anyone has it pls
  • Deku The one
    • Aug 2025
    • 3
    • 22286
    Originally posted by Deku The one
    are there any other numbers/letters on the board like CN-0G849F G849F 08212-1 48.4AQ01.011
    • Deku The one
      • Aug 2025
      • 3
      Yes i have, but not any like this.. I have just this one ACLU5/ACLU6 NM-A128 B122
        • 22286
        NM-A281 - https://www.badcaps.net/forum/troubl...m-a281-rev-1-0
        • Deku The one
          • Aug 2025
          • 3
          Thank you very much, i needed it like a week ago Hella i found it. I need to close this topic or?
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • makinen
            Acer SwiftX 14 SFX14-41G gh4fz LA-L202P Rev 1.0 board view file needed
            by makinen
            MB: Acer GH4FZ LA-L202P Rev 1.0
            Model no: Acer Swift SFX14-41G
            My laptop has random shutdown during use no matter high or low loading since a year ago, but still can be restarted. One day, it got very hot at the bottom near the power chip (PUB1) during use, and finally shutdown when in use and cannot switch on again (like dead), so I suppose there is no major failures and power issue should be fixable.
            There is no visual burnt or component damage, I tracked the power rail that the power seems blocked at charger chip (PUB1), measured some resistors...
            11-10-2025, 03:41 AM
          • m1ch43lzm
            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
            by m1ch43lzm
            Hi everyone
            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
            There's also an extra OTP Secu.R...
            09-06-2025, 05:47 PM
