mv-4 e89382 HannStar i need the board wiev file if anyone has it pls
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by makinenHello,
MB: Acer GH4FZ LA-L202P Rev 1.0
Model no: Acer Swift SFX14-41G
My laptop has random shutdown during use no matter high or low loading since a year ago, but still can be restarted. One day, it got very hot at the bottom near the power chip (PUB1) during use, and finally shutdown when in use and cannot switch on again (like dead), so I suppose there is no major failures and power issue should be fixable.
There is no visual burnt or component damage, I tracked the power rail that the power seems blocked at charger chip (PUB1), measured some resistors...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
- Loading...
