Panasonic Toughbook cf-20 mk1 schematics and boardviews
  • GorBars
    • May 2025
    • 3
    • Armenia
    Нужна схема платы cf-20
  • Aliencomputres
    • Aug 2019
    • 204
    • România
    heloo,
    post in english,pls.
    • GorBars
      • May 2025
      • 3
      • Armenia
      Hi. I need schematics and boardviews cf-20
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
      • eukal
        Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
        by eukal
        Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
        I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
        I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
        I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
        07-01-2023, 01:00 PM
      • Nedim Merdan
        Panasonic toughbook CF-D1DW200FZ motherboard DL3UP1969CAA schematic
        by Nedim Merdan
        Does anyone have the schematic for toughbook cf-d1 mk1 motherboard model is DL3UP1969CAA thanks in advance
        12-07-2024, 02:22 PM
      • David Smedley
        Panasonic FZ-55 Toughbook main board schematic request
        by David Smedley
        I've been working on this awful project with a Panasonic FZ-55, basically I'm trying to intercept the eDP signal from the main board, and replace it with my own eDP signal connected from an lcd driver. The problem is, for some reason the 30 pin ribbon pinout is really unusual and not playing nice with my LCD controller. Long story short, I managed to fuck up my board and pull off some pads on the eDP out port, I'm hoping to find either another eDP out source somewhere else on the laptop, or figure out this goddamn pin layout so I can just replace the whole native display complex with my controller...
        09-04-2024, 02:57 PM
      • eukal
        Need schematics for Panasonic Toughbook CF-H2 MK1.
        by eukal
        Hello i need schematics for Panasonic Toughbook CF-H2 MK1.
        Maybee other Mk (2-3) can work too.
        Thanks.
        07-01-2023, 12:40 PM
