Hp dv6 hpmh-41-ab6200-e00g
  • aanan
    • 222
    • India
    HP DV6 HPMH-41-AB6200-E00G
    laptop dead need schematic .
  • kuldeep
    • Sep 2013
    • 30
    • india
    Re: Hp dv6 hpmh-41-ab6200-e00g
    download ...
    • aanan
      • 222
      • India
      Thanks kuldeep.
      • aanan
        • 222
        • India
        i need actual board image some part & path missing.
        • kuldeep
          • Sep 2013
          • 30
          • india
          which part missing..??
          • aanan
            • 222
            • India
            near lvds connector.
            check inbox kuldeep.
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              Originally posted by kuldeep
              download ...
              thanks
              • diego.lv
                • Aug 2014
                • Brasil
                thanks =)
                • dj_ricoh
                  • 2073
                  ammm you need to know when you need to stop or never start investing time!
                  this is one of them fubar mainboards.
                  • winkoko
                    • Feb 2013
                    • 28
                    • myanmar
                    thanks
                    • joaquinmjuan
                      • Sep 2014
                      • 31
                      • España
                      download ...
                      Thanks for the schematic!!!!!!
                      • pocho89
                        • Jul 2015
                        • Agentina
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          dj_ricoh ... quiting is for weeks :P
                          i only quit if the bloody board is completely burned ...nothing possible to save.
                          if parts are missing , if not working , thats the real challenge ..specially the missing parts board ..i receive a lot of does kind of board here , since we do only work in resell mode , we are a lab and we receive machines frmo other stores. many times they come completely fucked up . even like this , we keep fixing them
                          • highpulse
                            i hate HP
                            • May 2013
                            • 1488
                            • portugal
                            and btw , that area there isn't much special unless capacitors near 19volts line.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              reworking and cleaning all layer with a dremel would fix this machine no problem
                              • Nadeem Amin
                                • 33
                                • pakistan
                                • habib_7_7
                                  • Nov 2015
                                  • 14
                                  • pakistan
                                  thanks bro
                                  • coder78
                                    • Aug 2015
                                    • 67
                                    • turkey
                                    thanks
                                    • afrosh
                                      • Oct 2012
                                      • 6
                                      • india
                                      thank you
                                      • hiepsiFix
                                        • Oct 2014
                                        • 3
                                        • Viet Nam
                                        Thanks!
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • Prabuth
                                          NEC Laptop VK26TX-M Schematic Need
                                          by Prabuth
                                          darr3amb6d0 rev d Schematic Need Please..
                                          NEC Laptop
                                          VK26TX-M
                                          07-05-2025, 02:00 AM
                                        • Loli Popu
                                          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                                          by Loli Popu
                                          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                          12-13-2024, 03:28 AM
                                        • thumper69
                                          Alienware M17x Laptop motherboard may be dead
                                          by thumper69
                                          We use a laptop to connect to an omron CPM2A serial port for programming and data transfer. Using a usb to serial adaptor and a blackbox connecting cable. The operator of the equipment had a failed ac power plug that powers the plc and changed it reversing the hot and neutral lines. the result was when connecting the plc to laptop it blew out adapter, plc, and laptop. apparently it sent 115 volt ac via ground into usb port of laptop. Laptop appears to try and power up but shuts down after a few seconds. Any repair possible or do i need new motherboard.
                                          09-03-2023, 06:41 AM
