Hp dv6 hpmh-41-ab6200-e00g
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    Re: Hp dv6 hpmh-41-ab6200-e00g
    thanks
    • st33693
      • Aug 2012
      • 22
      • iran
      • Am0rPHiA
        • Nov 2011
        • 31
        • Greece
        i have this board and it's dead, there is 3.3v on the power button, when its pressed it turns to 0 and stays like that, nothing overheats, i checked for shorts and didn't find anything, any ideas what to look?
        • mcoytzhi27
          Mr
          • Nov 2015
          • 43
          • philippines
          Big thanks
          • FOWJI
            • Dec 2015
            • 6
            • sri lanka
            • touita
              • Sep 2017
              • 8
              • المغرب
              #26
              thank u
              • ibrahim03
                • Oct 2015
                • 142
                • egypt
                #27
                thank you for sharing
                • lebana
                  • Jan 2015
                  • 81
                  • sudy
                  #28
                  thank u
                  • kato1
                    • Mar 2016
                    • 5
                    • turkiye
                    #29
                    Thanks for the schematic!!!!!!
                    • manana2019
                      • Apr 2019
                      • 32
                      • malaysia
                      #30
                      Thanks you sir.
                      • amirarbabi
                        • Feb 2019
                        • 33
                        • usa
                        #31
                        tnks
                        • bembeno
                          • Feb 2016
                          • 307
                          • egypt
                          #32
                          looking for schematic for HP DV6-6160sx
                          PCB:HPMH-41-AB6200-E00G
                          PWA:HPMH-40GAB 00- E
                          • victor_quiroga
                            • Dec 2014
                            • 61
                            • argentina
                            #33
                            thank you
                            • ibnalhabit
                              • Mar 2019
                              • 52
                              • ALGERIA
                              #34
                              thanks
                              • Jansen Carreira
                                • Jan 2025
                                • Brazil
                                #35
                                • dqtech
                                  Badcaps
                                  • Jul 2018
                                  • 624
                                  • N/A
                                  #36
                                  thanks
                                  • max-power
                                    Dell E6540 laptop completely dead after dssasembly
                                    by max-power
                                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                    03-24-2025, 08:49 AM
                                  • RdeveLabs
                                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                    by RdeveLabs
                                    To all the members here...
                                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                    05-05-2025, 04:59 AM
                                  • Prabuth
                                    NEC Laptop VK26TX-M Schematic Need
                                    by Prabuth
                                    darr3amb6d0 rev d Schematic Need Please..
                                    NEC Laptop
                                    VK26TX-M
                                    07-05-2025, 02:00 AM
                                  • Loli Popu
                                    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                                    by Loli Popu
                                    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                    12-13-2024, 03:28 AM
                                  • thumper69
                                    Alienware M17x Laptop motherboard may be dead
                                    by thumper69
                                    We use a laptop to connect to an omron CPM2A serial port for programming and data transfer. Using a usb to serial adaptor and a blackbox connecting cable. The operator of the equipment had a failed ac power plug that powers the plc and changed it reversing the hot and neutral lines. the result was when connecting the plc to laptop it blew out adapter, plc, and laptop. apparently it sent 115 volt ac via ground into usb port of laptop. Laptop appears to try and power up but shuts down after a few seconds. Any repair possible or do i need new motherboard.
                                    09-03-2023, 06:41 AM
