OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
  • bastien
    • Aug 2015
    • 16
    • France
    It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
    This is the new database for FlexBV
    it's optimized to work with it
    by using board ID has Default name, give us the opportunity,
    to use other diode board data with sibling board or family board
    I Merged the whole data (optimal)
    A2991 A2992 M3 -> -> 2 Entries diode data M1
    A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
    A2442 A2485 A2779 A2780 A2991 A2992 M1 M2 -> -> 2 Entries diode data M1
    A2337 A2179 A1932 -> -> 3 Entries diode data
    A2159 A2338 A2289 -> A2159 A2338 A2289 -> 2 Entries diode data
    A1989 A1990 A2141 A2251 -> -> 4 Entries diode data
    A1708 -> -> 2 Entries diode data
    A1706 A1707 -> -> 4 Entries diode data
    A1534 -> -> 2 Entries diode data
    A1502 -> -> 2 Entries diode data
    A1466 A1465 -> 820-000165 -> 1 Entries diode data
    A1398 -> -> 3 Entries diode data
  • rogerioms
    Rogerio Moya
    • Apr 2025
    • 7
    • Brazil
    Ty Bastien for share this boardview.. thanky very much.
    • firulilla
      • Jun 2014
      • 63
      • spain
      thanks four your work,,regards
      • bastien
        • Aug 2015
        • 16
        • France
        Hi friends, V2 will be finished soon the V1 was more a POC and the V2 is a lot more much more thoughtful, I can't ask for tips to do a better job for the community, now I should do the M2 and M3 and this is 4000 euros to buy, I will do the consoles and some drones, I do respect the rule from Bad caps, just i you're willing to help you will be welcome
        • ugamazing
          • Jun 2013
          • 165
          • usa
          bastien
          Thank you for all your hard work, it's much appreciated! Would you by chance be able to re-upload this program file? The forums experienced a breach/failure and it deleted all uploaded files.
            • 20869
            Originally posted by ugamazing
            bastien
            I had it on my PC, i`ve added the attachment back.
            • rogerioms
              Rogerio Moya
              • Apr 2025
              • 7
              • Brazil
              Thank you very much for sharing all the macbook information. I wish you all the best.
              • M4n0l0307
                • Nov 2020
                • 165
                • Colombia
                Thanks Friend !
                • envym
                  MacBook Pro 2018 with Activation Lock
                  by envym
                  Hi everyone!
                  I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                  I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                  06-27-2025, 08:54 AM
                • XxMicroSoldering
                  Lost Diode/Resistor RP802 MacBook Pro 2020 A2338 HELP
                  by XxMicroSoldering
                  Hello Guys. Yesterday I was repairing a MacBook with no backlight. I noticed the resistor/diode RP802 is bad so I took it off. I also had a faulty motherboard that can't be repaired that had that resistor/diode on it (RP802). So it took the good RP802 off the faulty board. And when I had it on my tweezers it accidentally flew away. And now I don't know what to do. I 100% can't find it because of how small it is. Do you guys know any other diode/resistor that can work as the RP802
                  I'm a newbie to microsoldering and I'm still learning. All help is really appreciated
                  10-06-2022, 12:41 AM
                • tobeend
                  Bypass mdm macbook m2 ventura
                  by tobeend
                  1. RESET MACOS WITH IPSW
                  a. Power off MacBook, press and hold the power button to enter Recovery
                  b. Open Disk Utility, remove Macintosh HD
                  c. Reboot, connect to the network to Activate Mac.
                  d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                  d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                  e. Release the other keys, but keep holding the Power key for another 10 seconds
                  f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                  05-26-2023, 07:18 AM
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
                • Cbizz
                  Help Identifying Diode for Macbook Air a1466 with 820-00165 board
                  by Cbizz
                  While reviewing the a1466 820-00165 board schematics, I came across a diode that I need to identify. The part in question is labeled D2920 (NSR1020MW2T1G), but my problem is that the schematic has the icon for a Zener Diode, but when I look up the part number, I only get results for a Schottky Diode. I don't have much experience with technical schematics at all and this part just so happens to be missing from the board I am trying to fix so I need to get my hands on the correct replacement part.
                  I have attached both the schematic portion in question and a screenshot of the part...
                  11-13-2021, 02:11 AM
