Hi evreyone plz needed boardview dell inspiron 15 3520 GDM LA-L24LP
Dell inspiron 15 3520 GDM LA-L24LP boardview or schematic
by Stanley1843Hello,
I bought a used Dell Inspiron 15 3520 laptop and the battery isn't charging. When I go to the BIOS setting it shows that the battery health is "excellent" but on the AC Adapter shows "not installed". I checked the pins from the power connector on the motherboard and I didn't found a short on the PS_ID pin. It dould be the charger (I don't know if this is the original) or what I have to check?... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
by Dan JohnGreetings everyone,
I am having an issue with the PSID on a DELL INSPIRON 13-5378 laptop. Can anyone please provide me with the schematics and/or boardview file? The BOARD NAME I believe is 0P380W but I have also seen STARLORD13 in some other places. Thanks for your help!2 Photos-
by jacospamaDell inspiron 15 3520 Bios needed
Reg Model- p112f
REg type- p112f00f
Services tag- BLW01Z3...-
Channel: BIOS Requests ONLY!
by EpicFixKindly asking for schematics and boardview for:
Dell Inspiron 3530
Board IDH50 LA-M366P
Any help rendered greatly appreciated. Thanks in advance 😊....-
- Loading...
