need explain diagram
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3573
    • slovakia
    Hello, i need to explain one thing on diagram.
    I need to know what is that numbers.
    Please see the picture.
    http://www.fastimages.eu/images/a.bmp
  • loser18
    • Nov 2013
    • 274
    Re: need explain diagram
    They're page numbers of schematic where the particular rail, signal, voltage etc goes..
    nemas za co
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3573
      • slovakia
      thanks. diky moc
      • gabri2211
        I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
        by gabri2211
        hello everyone, I'm looking for the wiring diagram of this led monitor.
        the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
        I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
        I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
        thanks to those who will answer
        12-10-2024, 04:37 PM
      • Thunderace7
        Cooker Hood Repair
        by Thunderace7
        Hi.
        I've been repairing a cooker hood for my daughter and, although I have got it working, I am puzzled by a couple of things.
        I have attached the circuit diagram I made from studying the PCB. It is a bit rudimentary but it served its purpose.
        There is a buzzer, driven by output P0.0 of the processor, and the circuit seems to be a bit strange. The buzzer seems to be continually powered by 12 volts but is short circuited by the driver transistor. Any idea why this should be? I have checked the PCB several times and this is definitely how it is wired.
        The second thing...
        11-02-2023, 09:46 AM
      • chudofermer
        Asus Ally rc71l bios
        by chudofermer
        Hello!
        Received Asus Ally rc71l with the wrong bios.
        Have the original package and all serial numbers.
        Can anyone help me understand what is wrong?
        Condition:
        Received with an original box with all serial numbers
        Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
        Got the flash dump, nothing found on DMI section
        No Windows key, just key ID on the box
        What is done:
        1. Flash the latest bios version with serial numbers...
        03-05-2025, 05:42 AM
      • Tarot Superstars
        How The AC stage of an Adaptor works
        by Tarot Superstars
        Hi. I have been watching videos on how a power adaptor works.
        There is explanation of the rectifier bridge to the pulse width modulator, the mosfet for switching, and opto-couplers, but there is little to nothing about the AC stage of the transformer the powers the primary coil.
        So, I see that the PWM needs DC to work, but I don't see anything about how the AC gets from the mains supply to the transformer stage.
        A transformer only works on AC so where is that part of the circuit.
        I only see Capacitors on the output. Should I assume that the secondary coil and...
        09-27-2023, 01:00 PM
      • Joseph Abraham
        skyworth air conditioner control board schematic diagram needs
        by Joseph Abraham
        hi every body 😗
        i have two air conditioners skyworth brand and i need schematic diagram of control board, acutely they did not work any more ( compressor startup failure ) and display appears ( H1 ) error code, any help plz to diagnostic this problem and how to fix it?
        i will be very appreciate thankyou 🤗
        Yesterday, 09:07 AM
