skyworth air conditioner control board schematic diagram needs
  • Joseph Abraham
    • Jul 2025
    • uae
    hi every body 😗
    i have two air conditioners skyworth brand and i need schematic diagram of control board, acutely they did not work any more ( compressor startup failure ) and display appears ( H1 ) error code, any help plz to diagnostic this problem and how to fix it?
    i will be very appreciate thankyou 🤗
  • hs5424
    Dynacord powermate 1600 block diagram.
    by hs5424
    Hi All,
    I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
    The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
    07-31-2025, 01:35 PM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • gabri2211
    I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
    by gabri2211
    hello everyone, I'm looking for the wiring diagram of this led monitor.
    the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
    I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
    I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
    thanks to those who will answer
    12-10-2024, 04:37 PM
    High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
    I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
    This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
    If it cycling on and off constantly then it is the bulb itself that is the issue
    06-03-2023, 05:24 PM
  • harp
    triac phase control 0-100%
    by harp
    Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
    06-02-2024, 09:00 AM
