See attached.
Thinkpad Tablet 2 Boardview file
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by Maxpower3Info for error 2202 LenovoThinkPad models and type
Extract from ThinkPad Maintenance Utilities Configuration File
plnsrv.ini Version 1.01
Some information that may be useful
There must also be missing models, add them to the list if you know of any.
...Code:brand name 20B1=ThinkPad Edge E445 20B2=ThinkPad Edge E545 20BC=ThinkPad Edge E145 20BM=ThinkPad X140e 20BL=ThinkPad X140e 20A3=ThinkPad X230s 20AH=ThinkPad X230s 20AK=ThinkPad X240s 20AJ=ThinkPad X240s
by PaffoHello,
i am trying to convert the LCD to be used standalone, but the connector is a non-standard 30 Pin. Before i make a converted connector to standard, i want to verify the PINs are correct.
Anyone has the schematic and board view of this motherboard (Thinkpad Tablet 10 (20C1, 20C3))?
Thanks-
by DevicemodderI recently discovered that the dock connector on the Thinkpad X1 tablet Gen 3 uses USB for the keyboard on the POGO pins, I want to use that connector to add a USB 2.0 hub to my tablet case (lenovo medical case for the X1 tablet)
Can't find much info on that bit online, but found lots of info for converting the Keyboards to USB. I wired up a USB port following https://sharktastica.co.uk/resources/im ... ogo-6p.jpg
If i connect a 10K resistor between ground/pin1 and pin5 (NC) i get a USB ding and then i see voltage on the 5V pin, but it drops to 2-3V when i plug in a... -
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
