Hacking the keyboard connector on my thinkpad X1 tablet Gen 3
  • Devicemodder
    • Jul 2023
    I recently discovered that the dock connector on the Thinkpad X1 tablet Gen 3 uses USB for the keyboard on the POGO pins, I want to use that connector to add a USB 2.0 hub to my tablet case (lenovo medical case for the X1 tablet)
    Can't find much info on that bit online, but found lots of info for converting the Keyboards to USB. I wired up a USB port following https://sharktastica.co.uk/resources/im ... ogo-6p.jpg
    If i connect a 10K resistor between ground/pin1 and pin5 (NC) i get a USB ding and then i see voltage on the 5V pin, but it drops to 2-3V when i plug in a flash drive and windows gives me a "USB device not recognized". but... if i supply external 5V to the flash drive, with the power disconnected from the tablet 5v pin, the tablet recognized and mounts the flash drive. there's gotta be a way to keep the USB pin voltage stable. unless it's going overcurrent trying to run a flash drive...​
    Dunno if anyone has done what i am trying to attempt before. Basically, need to somehow trick the tablet into thinking a keyboard is attatched, so i can activate and use the USB port without an external power supply on the USB.
  • mon2
    • 14691
    Not sure I am following your experiment but suggest the following:
    Mate only the D+ / D- and ground (3 wires) to your external hub controller. Power the external hub using another power adapter so that the downstream devices can be powered by the hefty USB hub power supply.
    That is all that should be required. The D+/D- are the USB signals. Try this idea and post your updates.
    • Devicemodder
      • Jul 2023
      That is how i discovered originally that the flash drive mounts over USB from the keyboard connector. IIRC, said keyboard is also powered from the pogo port. I'm trying to get that power to run a hub self contained on the back of my tablet case and powered from the tablet.
      But to get the tablet to recognize anything on the connector, i have to use a 10K resistor on ground and pin 5.
        Lenovo ThinkPad X1 Tablet (3rd Gen) Hybrid (2-in-1) X Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad X1 Tablet (3rd Gen) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Tablet (3rd Gen) boardview and X1 Tablet (3rd Gen) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 08:47 AM
      • Maxpower3
        Brand name and Model Type for Lenovo error 2202 product name is invalid
        by Maxpower3
        Info for error 2202 LenovoThinkPad models and type
        Extract from ThinkPad Maintenance Utilities Configuration File
        plnsrv.ini Version 1.01
        Some information that may be useful
        There must also be missing models, add them to the list if you know of any.
        Code:
        brand name
        20B1=ThinkPad Edge E445
        20B2=ThinkPad Edge E545
        20BC=ThinkPad Edge E145
        20BM=ThinkPad X140e
        20BL=ThinkPad X140e
        20A3=ThinkPad X230s
        20AH=ThinkPad X230s
        20AK=ThinkPad X240s
        20AJ=ThinkPad X240s
        02-21-2024, 10:27 AM
      • Paffo
        Thinkpad Tablet 2 (2679) No Power
        by Paffo
        I recently got my hands on a batch of Thinkpad Tablet 2 that a local business was throwing away. They all have the same issue, no Power.
        I do have a working one that i also took and the first thing i did was trying to power it without the battery being inserted.
        It seems that these tablets do not work unless the battery is in (my PSU is 5V5A so i doubt it's a current thing, probably design).
        I thought i'd be lucky so i took the battery from the working one and i tried it in 2-3 of the broken ones, but no luck, still no power.
        The current draw is 18mA...
        07-05-2024, 03:30 PM
      • what_1282105
        Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
        by what_1282105
        Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
        02-14-2025, 07:27 PM
        Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-06-2024, 11:40 AM
