Msi Wind U160 schematic needed
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Hello guys, need schematic for this netbook MSI Wind U160 (U160-040XPH) It has power but no video even in external mode. Lotsa thanks
  • dj_ricoh
    • 2073
    Re: Msi Wind U160 schematic needed
    did you try a reflow?
    it has a soldered CPU
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      Yes I did, but no success. Owner told me he put laptop in sleep mode and never returned
      I just want to check something before I flash bios.
      • dj_ricoh
        • 2073
        i did one time something like that.
        try to read the bios save it , delete and write back the file.
        it work once for me.
        maybe you get lucky
        • tomodachi
          • Apr 2012
          • 610
          • Turkey
          MS-*** code please
          • tomodachi
            • Apr 2012
            • 610
            • Turkey
            Here u go, pwd is " ERC "
            • lezsimply
              The Wanderer
              • 657
              • Philippines
              Thank you very much todomachi! have a nice day.
              @ dj I will try it too, thanks very much also.
              • tomodachi
                • Apr 2012
                • 610
                • Turkey
                np, this motherboards has 7 different revisions. if above doesn't fit yours then tell me and I share others
                • lezsimply
                  The Wanderer
                  • 657
                  • Philippines
                  This board's code is MS-N0511 ver 1.2 Do you have schematic version for this one, Thanks in advance!
                  I've got a slight problem regarding this. I successfully reprogrammed bios chip but while I was cleaning the board a small tiny smd resistor fell off. I'm assuming that it came somewhere near bios chip. Its the only place I touched during the process.
                  As you can see in the image, I just placed the resistor back at R401 but I'm not sure if its really there or not. its the only place I can think of close enough for my soldering iron to bump into. I'm also looking at R474 and I doubt that the tip would reach that and the resistor reads 4.6k in my meter. Just try to confirm it. Thanks again
                  • lezsimply
                    The Wanderer
                    • 657
                    • Philippines
                    well I guess it sits there aside from reference motherboards I saw from ebay, diagram shows 4.7k ohms. so its possible that R401 is correct.
                    • lezsimply
                      The Wanderer
                      • 657
                      • Philippines
                      Good news! This laptop now has display. Bios reprogram is successful. At first,I tried bios which came from its chip but did not work so I downloaded from msi website and that worked. I attached file. Thanks
                      Last edited by lezsimply; 02-16-2014, 01:05 AM. Reason: forgot to attach bios file
                      • tomodachi
                        • Apr 2012
                        • 610
                        • Turkey
                        good to see you beat it !
                        • huu.hido
                          • May 2015
                          • viet nam
                          cảm ơn nhiều= thanks very much
                          • Roman123
                            • Oct 2015
                            • 7
                            • RUSSIA
                            Thank you very much tomodachi anywhere could not find
                            • boss juben
                              • Oct 2016
                              • 37
                              • philippines
                              thanks for the bios
