DA00PDMB8E0 Rev:E schematic and boardview
  • Zartech97
    newbie
    • Nov 2023
    • Malaysia
    hi everyone, i need some help getting this schematic and boardview if available
    board no : DA00PDMB8E0 rev:E
  • Allgone
    • Jul 2023
    • 13
    • Spain
    What is the model?
    • CarlsonChin
      • May 2024
      • Malaysia
      Originally posted by Allgone
      What is the model?
      15-FC0102AU
      • McKey
        • Jun 2024
        • 53
        • Hungary
        Hi, i have the same board currently on my desk with a shorted 7626j on the usb-c power input. If you just need some measurements, may i can help you.
        • sasser
          • Dec 2012
          • 365
          • Malaysia
          check ic 3324p with pin usb
          • PacoGT
            HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
            by PacoGT
            hello firends
            i search the schematic or boardview
            I have this motherboard, but I can't find the schematic or the boardview.
            The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
            So the computer doesn't turn on, and the 3V disappears after a few seconds.
            The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
            The new problem arose after removing the bad chip.
            3V and 5V remained together,...
            08-19-2025, 08:25 PM
          • hosain0489
            Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
            by hosain0489
            I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
            Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
            If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
            Thank you very much in advance!
            07-15-2025, 11:20 AM
          • re-atari
            Gigabyte GA-H110-D3A schematic/boardview needed
            by re-atari
            Hello all,
            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
            02-24-2025, 06:45 PM
          • jonyhdtv
            HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
            by jonyhdtv
            Looking for schematic and boardview
            Model: HP ProBook X360 11 G3 EE
            Serial: SCG9114JG7
            Motherboard: L43774-601
            defect: touchscreen doesn't work (touch works on another computer)
            thanks to all​
            01-29-2025, 08:16 AM
          • jonyhdtv
            HP ProBook X360 11 G5 ee schematic and boardview thanks
            by jonyhdtv
            HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
            Model: HP ProBook X360 11 G5 EE
            Serial: SCG0164QLH
            Motherboard: L83950-601
            defect: no POWER
            thanks to all​
            01-29-2025, 08:11 AM
