NMC511 / NM-C511 Boardview + Schematic
  • Wolfrahm
    • Sep 2017
    • 15
    • Ukraine
    NMC511 Rev. 1.0 Boardview, schematic.
    Memory configuration on page 7.
    For DIMM_Only:
    Board_ID2 - 0 (RC1612)
    Board_ID3 - 1 (RC1609)
    Board_ID4 - 0 (RC1607)
  • bratapita
    • Sep 2023
    • 9
    • Poland
    Thanks.
    • oghatian
      • May 2015
      • 8
      • The Netherlands
      Thanks, you are a life saver 🙏👍
      • Jiaoxian Wei
        • Oct 2021
        • china
        Thank you, amigo
        • pro100service
          • Russia
          NM-C511 Rev. 1.0 Boardview, schematic
          • aksdbaksh
            • Jun 2018
            • 8
            • iraq
            Thank you!
            • PacoGT
              HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
              by PacoGT
              hello firends
              i search the schematic or boardview
              I have this motherboard, but I can't find the schematic or the boardview.
              The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
              So the computer doesn't turn on, and the 3V disappears after a few seconds.
              The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
              The new problem arose after removing the bad chip.
              3V and 5V remained together,...
              08-19-2025, 08:25 PM
            • hosain0489
              Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
              by hosain0489
              I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
              Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
              If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
              Thank you very much in advance!
              07-15-2025, 11:20 AM
            • re-atari
              Gigabyte GA-H110-D3A schematic/boardview needed
              by re-atari
              Hello all,
              Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
              This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
              02-24-2025, 06:45 PM
            • jonyhdtv
              HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
              by jonyhdtv
              Looking for schematic and boardview
              Model: HP ProBook X360 11 G3 EE
              Serial: SCG9114JG7
              Motherboard: L43774-601
              defect: touchscreen doesn't work (touch works on another computer)
              thanks to all​
              01-29-2025, 08:16 AM
            • jonyhdtv
              HP ProBook X360 11 G5 ee schematic and boardview thanks
              by jonyhdtv
              HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
              Model: HP ProBook X360 11 G5 EE
              Serial: SCG0164QLH
              Motherboard: L83950-601
              defect: no POWER
              thanks to all​
              01-29-2025, 08:11 AM
