toshiba satellite L650 Bl10 UMA schematic
  • smoovie2003
    • Mar 2013
    • 9
    • Pakistan
    Hi guys,
    need the schematic for a toshiba satellite L650 Bl10 UMA rev 2
    Ive got no post, powers on ok, reballed the intel gpu/chipset (symptoms pointed out it could have been that but still the problem persists)..powers on ..no post...changed the cmos battery...i need to check the bios chip but need the schematic..have no clue which one is the bios chip..please help..
    thanks!
  • alihomee
    • Dec 2012
    • 1582
    • malaysia
    Re: toshiba satellite L650 Bl10 UMA
    did u have power in your unit
    • smoovie2003
      • Mar 2013
      • 9
      • Pakistan
      Yes, as i said before it powers on ok...no post (no display). Symptoms are for a bad soldering gpu chip...but reballed twice..so i can rule that out.
      • Francisco.s
        • 686
        • Spain
        Originally posted by smoovie2003
        Hi guys,
        thanks!
        Here you are. Bios U300 page 14.
        • smoovie2003
          • Mar 2013
          • 9
          • Pakistan
          Thanks for the reply Francisco..ive got that schematic (BL10G) but the board is BL10 its an older version rev 3...not BL10G.. the markings and chip numbering is different..there might be some components in common but they have different markings...thanks again!
          this is the exact code : INVENTEC Berlin 10 BL10 6050A2332401-MB-A03.
          • smoovie2003
            • Mar 2013
            • 9
            • Pakistan
            http://uk.alibaba.com/product/543036...B-A03-Sub.html
            this is the board...its the ddr3 version.
            • smoovie2003
              • Mar 2013
              • 9
              • Pakistan
              I took a second look and i found the chip..it seems they are similar..the schematics..thanks..ill check it to see if the chip is damaged...it does not post..powers on ok... thanks again!
              • Francisco.s
                • 686
                • Spain
                If bios chip have data corruption, the only way to know, is de-solder it and reprogram with new good data.
                Regards.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Was this ever fixed?
                  Muh-soggy-knee
                  • smoovie2003
                    • Mar 2013
                    • 9
                    • Pakistan
                    Ok...back to this project...abandoned due to unabled to fix....
                    So it powers on, stays on for 20 secs..then powers off...then powers on again...its a power loop of 20 sec duration...
                    i removed the bios chip and rewritten it with a newer version of fd...no change.
                    Can anyone help please?
                    Could this be a power failure or a bad cap...as i said before..i removed and swapped 2 bga chips (intel) because i thought it was a gpu fault but no improvement.
                    The bga gets hot though...after 15 secs of power...this model seems to have poor heatsink system...the bga has no copper shim or heatsink!
                    please help with a hint.
                    once again: no display....power loop after 20 sec.. could this be a power issue? tested and battery is charging.
                    • trebo
                      • 514
                      • Wales, UK
                      that could be bad CPU, try swapping with a known good one
                      • smoovie2003
                        • Mar 2013
                        • 9
                        • Pakistan
                        already did...i have experience..ruled out ram..cpu...bios chip.
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1488
                          • portugal
                          well what happen is that a abnormality is beeing reported to the KB and KB is shuting down the mobo , so i would go for the main thing , chek all S0 when pressed ON (chek all coils and report us voltages present .) after that we can start rulling out some outher options , but does values would be very apreciated to help you out !
                          • whaldsz
                            • Apr 2013
                            • 395
                            • Philippines
                            wouldn't hurt to reprogram the bios first.
                            • dj_ricoh
                              • 2073
                              • uk
                              he did!
                              do you have the schematic?
                              i can`t download it
                              • hansie55
                                • Dec 2013
                                • 254
                                • Netherlands
                                dj, you still need the schematic?
                                • Ramee
                                  • Jul 2014
                                  • 218
                                  • Israel
                                  Originally posted by dj_ricoh
                                  he did!
                                  i can`t download it
                                  Here
