HP 4515s scheme
  • lord
    • May 2011
    • 319
    • Croatia
    HP 4515s scheme
    I did a reball on the IGP (i was sure that this was the problem because i preheat it and it worked). So everything went well, but when i powered on the laptop the smoke come out of a tranzistor of some kind. I removed it and the voltages on the pins on the board are 30-50V
    So i need a scheme to track what it generating that voltages and what is that part that let the white smoke out.
    BTW Did you know that all electronic devices work on white smoke? Because when the white smoke comes out, the don't work no more
  • siddiq
    • Dec 2011
    • 121
    • Ghana
    Re: HP 4515s scheme
    You need to show us the motherboard model.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Re: HP 4515s scheme
      try this (amd cpu descrete vga)
      you really need to start giving some more details, especially if its HP/Compaq...
      Im Back... sort of...
      • lord
        • May 2011
        • 319
        • Croatia
        Re: HP 4515s scheme
        Ah, sorry. I will remember this.
        It is the 585219-001 rev:4.21 Hannstar made board. I think this is the Hannstar P/N: 6050a2268201-mb-a02
        Donny - this is not the scheme that I'm looking for.
        • heavymachines
          • Mar 2011
          • 1028
          Re: HP 4515s scheme
          sounds like the reball went bad ........probably most likely have couple "pins" bridged underneath the igp chip .... if it worked good after a partial "reflow" then you did a reball and everything went "south" and frying components most likely you bridged a couple pins under that bga igp chip.....therefor throwing voltages out of wack.....due to short...
          • lord
            • May 2011
            • 319
            • Croatia
            Re: HP 4515s scheme
            I can repeat the reball process.
            Anyway i don't see a way how can this happen. I reballed chips and chips, and never have this happened, but maybe you're right, since i don't see anything else that could go wrong. Specially when it worked after a partial reflow.
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              Re: HP 4515s scheme
              here is your schematics but i cant download from there
              maybe someone else could
              Code:
              http://www.elvikom.pl/forum/viewtopic.php?p=72690#p72690
              • lord
                • May 2011
                • 319
                • Croatia
                Re: HP 4515s scheme
                I registered, logged in, but don't have enough points?!?!?
                • selldoor
                  Slow Learner
                  • 7870
                  Re: HP 4515s scheme
                  I dont know if it bears any resemblance but here is something for a 4520S
                  • lord
                    • May 2011
                    • 319
                    • Croatia
                    Re: HP 4515s scheme
                    I will compare it later, altough at first glance i think it will not do.
                    Anyway thanks for the effort!
                    • lord
                      • May 2011
                      • 319
                      • Croatia
                      Re: HP 4515s scheme
                      Nope. It is not the right scheme.
                      Still looking for it. Just so we don't forget i need a scheme for a HP 4515s motherboard. The motherboard details are 585219-001 Rev 4.21, also found a Hannstar P/N 6050A2268201-MB-A02.
                      Thank you very much!
                      Regards from Croatia,
                      Darko
                      • lord
                        • May 2011
                        • 319
                        • Croatia
                        Re: HP 4515s scheme
                        You were right. But i didn't want to risk with the old chip so i replaced it. Anyway, how i got the picture, but evereything is RED???
                        It is not the screen nor the flat cable. Any one has a clue?
                        Thanks in advance!
                        • lord
                          • May 2011
                          • 319
                          • Croatia
                          Re: HP 4515s scheme
                          Anybody? Red picture?
                          • dj_ricoh
                            • 2073
                            Re: HP 4515s scheme
                            yes! i had a acer with i5 that give us red tone on the screen we replace the screen and every screen got another color. the chip was reflow then all went well and work fine.
                            youre reball did not went well. my XP
                            • fddizon
                              • Sep 2011
                              • 555
                              • Philippines
                              Re: HP 4515s scheme
                              reball again
                              • lord
                                • May 2011
                                • 319
                                • Croatia
                                Re: HP 4515s scheme
                                Client gave up at the end. So the little HP has a red picture
                                • spidey
                                  climbs
                                  • Dec 2012
                                  • 644
                                  • Cyprus
                                  Re: HP 4515s scheme
                                  http://wenku.baidu.com/view/142d7a2c...122b91.html###
                                  • evgraf
                                    • Sep 2014
                                    • ua
                                    Re: HP 4515s scheme
                                    All scheme no mach P/N 6050A2268201-MB-A02.
                                    • Bybuca35
                                      • Apr 2017
                                      • 11
                                      • VVVvvv
                                      Re: HP 4515s scheme
                                      Http://www.elvikom.pl/forum/viewtopi...p=72690#p72690
                                        MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:46 AM
                                        MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                        09-06-2024, 07:29 AM
                                        MSI Prestige P65 8RF-445ES Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-445ES Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-445ES Creator White boardview and P65 8RF-445ES Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-06-2024, 07:25 AM
                                        MSI Prestige P65 8RF Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF Creator White boardview and P65 8RF Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        MSI Prestige P65 8RF-457BE Creator White Notebook P Specification for Upgrade or Repair
                                        This specification for the MSI Prestige P65 8RF-457BE Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-457BE Creator White boardview and P65 8RF-457BE Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
