No matrix backlight on msi ms-163n schematic
  • geniusbo
    • Feb 2023
    • belarus
    Help is needed. The converter is not supplied with voltage 3.3 to turn on the matrix. The adjustment when you press fn works, I checked it by connecting a 3v battery - the backlight works. There is no enable signal on the motherboard on the pin. Maybe you have a diagram for it. msi ms-163n1 rev 1.0
    sorry for my English
  • Stephen
    A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
    by Stephen
    Hello, got a weird MacBook Air here
    board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
    08-23-2023, 09:12 AM
  • zaurus81
    Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
    by zaurus81
    This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
    The board is equipped...
    01-16-2025, 03:54 AM
  • vf fa
    EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
    by vf fa
    Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
    I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
    So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
    01-31-2024, 01:40 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
