Need bios HP 450 g4 7th gen DA0X83MB6H0
  • alix1
    • Aug 2022
    • 20
    • beirut
    Need bios HP 450 g4 7th gen DA0X83MB6H0 p85
    hi my bios worked fine but i have a problems with them.
    The first one work all fine but the computer take 1 min to turned on.
    The other one turn on very fast but can't boot when i boot from legacy or uefi it will just restart the computer.
    I will post my bios here if any one have a solution please help .
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    Re: Need bios HP 450 g4 7th gen DA0X83MB6H0
    Which one of them is your original backup?
    all donations are welcome,
    • peste
      • 13921
      • ROMANIA
      try...
      • Gael Jesús
        • Aug 2021
        • México
        Originally posted by peste
        try...
        It works 100% OK! With this BIOS I solve password problems and the display time. I appreciate it a lot
        • alix1
          • Aug 2022
          • 20
          • beirut
          try...
          thanks !
          • kenkaniff
            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
            by kenkaniff
            Product Name: HP Pro x360 Fortis 11-inch G9
            System BIOS: U94 Ver.01.08.00 10/06/2023
            Serial Number: 5CG31946F5
            SKU Number: 85W05EC#AK8
            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
            I needed to remove bios password...
            10-01-2025, 04:32 AM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • q2v5
            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
            by q2v5
            Lenovo T480s
            Model 20L8-S3TE00
            Board ET481-U10
            Chip MX25L12873F
            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
            08-15-2024, 10:40 PM
          • Max029
            Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
            by Max029
            I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
            I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
            TY,
            08-18-2024, 08:28 PM
          • 0xx
            2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
            by 0xx
            Hi folks,
            My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
            What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
            I assumed that Windows Update was interrupted due to closing...
            09-14-2025, 03:46 PM
