I need bios dump for Elitebook 830 G7
  • hamodeh
    • Dec 2017
    • 71
    • IRAQ
    #61
    yes i made one me region but maybe not works , the device takes 30 sec to open
    can you clear my file by your selfie
    or what your options for this case ?!!
    • danito
      • Jun 2016
      • 1218
      • Romania
      #62
      try, the first start will take longer.
      • Bigdogfr57
        • Nov 2025
        • 4
        • France
        #63
        Hello danito,
        Could you please have a look at my previous post about SRP1 = 1 on my WINBOND Chipset ?
        Does it make a brick chipset that should be replaced ?
        Then if i need to replace it by a new one, which BIOS i should flash on it ?
        Thanks a lot in advance,
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
          by haitham sharabati
          Hello engineers 😀,
          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
          💀 Problem:😅
          - Device shows “Administrator Password”...
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
