asus gl503vm bios chip
  • dumblejd
    • Dec 2022
    • 10
    hi, I got a laptop with bios password, so I want to get rid of it...
    I open the laptop and found this chip which looks like bios chip to me
    winbond 25q64jvs. and I flashed the bios on official web https://www.asus.com/supportonly/rog...helpdesk_bios/
    1. I tried all two bios, the laptop can't boot now, fan not running.
    2. the ch341a I use works for sure, I flashed two devices bios with it today.
    My question is...this chip in picture is that a bios chip or what should I flash in...
    https://imgur.com/a/ssNPtVJ
    some gl503 take apart video on youtube https://www.youtube.com/results?sear...vm+disassembly
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Re: asus gl503vm bios chip
    Winbond 25q64jvs if that's what written on the chip in your Pic, so that will be your bios chip.
    Now as I see your main problem was bios password, and after you used a bios from official website the laptop doesn't work.
    What if you program back your original file, the laptop works or not?
    Also upload your original file here if you want someone to remove your password.
    all donations are welcome,
    • dumblejd
      • Dec 2022
      • 10
      auuuu. that's the stupid part, I didn't backup old one. I've been lucky with bios chip flash...this is the point I learn backup everything. I will try flash again before I call it dead.
      one more question, for asud bios, I just download that file and change it to .bin right?
      • lapfix
        • Mar 2020
        • 2765
        • my workshop
        NO
        is there any sticker at ram slot !! if yes post the picture and the picture for the asus reference marqued at motherboard
        • dumblejd
          • Dec 2022
          • 10
          Originally posted by lapfix
          NO
          no sticker on ram slot that tells mobo info. I also can't see any identifier like desktop mobo. the laptop model is GL503VM. does mobo info matter for extracting .bin file from official asus bios file?
          • lapfix
            • Mar 2020
            • 2765
            • my workshop
            Yes it makes differenes
            read this : https://www.badcaps.net/forum/showth...ight=asus+x555
            • dumblejd
              • Dec 2022
              • 10
              just take off the fan and everything off the mobo. I think I found something to identify the mobo. it's under a blacksticker under ssd.
              I google this numebr and it bring me page to laptop motherboard:
              DABKLMB1AA0 REV:A
              • cacla
                • Apr 2015
                • 444
                Here mate i think this is the one for you
                If dont start with this bios give me unit sn and i will find the right bios for it
                • dumblejd
                  • Dec 2022
                  • 10
                  Thank! can I use this with ch341a after changing this file to .bin? this file seems exactly same as official biso file (same size of 8,388,608)
                  • cacla
                    • Apr 2015
                    • 444
                    Mate this is form F1 bios its .bin
                    • dumblejd
                      • Dec 2022
                      • 10
                      oh god thanks. this file works. every time ch341a work, it feel like magic. really appreciate your help.
                      • cacla
                        • Apr 2015
                        • 444
                        Your notebook is now ok?
                        • dumblejd
                          • Dec 2022
                          • 10
                          yep. it works now.
                          • BMCappelletti
                            Asus Chromebox CN62 - wrong chip put on BIOS reader
                            by BMCappelletti
                            Long story short:
                            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                            - gave the computer to his son a couple years later
                            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                            (seems like the story was not that short)
                            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                            01-08-2025, 07:27 PM
                          • DynaxSC
                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                            by DynaxSC
                            Hi
                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                            08-04-2025, 12:20 PM
                            Common SPI bios chip programming Questions and Answers
                            by SMDFlea
                            Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                            A: If you can`t read from it how do you expect to write to it ?.
                            Q: Why is my bios chip unreadable ?.
                            A: The programmer is faulty or has a worn or broken zif socket.
                            The USB cable is frayed,connector pins worn or some other physical damage.
                            Not enough amperage or voltage to power the programmer properly.
                            Bad...
                            09-02-2021, 04:40 PM
                          • razor_amd
                            by razor_amd
                            12-15-2020, 07:07 PM
                          • JoWed
                            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                            by JoWed
                            Hello Community,
                            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                            07-01-2025, 09:32 AM
