Please repair my Asus TP410UA bios
  • bilen
    • Aug 2014
    • 638
    • istanbul
    problem no screen. I tried the bios in the forum. not working
    can you repair my original bios
  • lapfix
    • Mar 2020
    • 2724
    • my workshop
    Re: Please repair my Asus TP410UA bios
    Try
    • bilen
      • Aug 2014
      • 638
      • istanbul
      Originally posted by lapfix
      Try
      nothing has changed. not working
      • bilen
        • Aug 2014
        • 638
        • istanbul
        i solved the problem
        onboard ram faulty liquid contact
        Is there a way to disable the onboard ram?
        • lapfix
          • Mar 2020
          • 2724
          • my workshop
          Try and feedback
          • lrouw84
            by lrouw84
            Hi there,
            01-28-2023, 01:31 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • maciek1221
            Looking for a bios for Asus G512-LV with RTX2060 and bios for VGA chip
            by maciek1221
            Hello, I am looking for a bios insert for the Asus Rog Strix G512LV-HN235T laptop. We are looking for input for both the BIOS and the small chip for the graphics card. The laptop came to me after another service with the wrong BIOS (no serial number, the problem with the meregion turns on for more than a minute). After uploading a few batches, I have an exclamation mark next to the Nvidia RTX2060 graphics card, I suspect one of the 2 BIOS batches is incorrect.
            Config:
            Model: Asus G512LV-HN235T
            Platforma: G532LWS rev. 1.3
            CPU: intel i7-10870H
            GPU: nVidia Geforce RTX2060/...
            03-07-2024, 07:54 AM
          • Technodoc
            ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
            by Technodoc
            Asus laptop G614JZ-N3012W Rog Strix with i7
            Mainboard G634J-PMV-VGT
            6050A3441302-MB-A01
            2023-02-10
            Power button works okay....power light goes on
            Red "bottom" leds go on
            Charging led works
            Fans do not spin, capslock key does nothing, screen stays black
            I would like to program the bios again, to rule out a corrupted bios.
            However I run into a size error
            The bios chip is a Winbond 25R256JVEN
            Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
            02-24-2025, 04:46 AM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
