pls help my i need bios Vostro A860
  • hamada2h
    • Nov 2018
    • 7
    • egypt
    pls help my
    i need bios
    DA0VM9MB6B0 REV B
    rev: A01
    PWA: m712H
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: pls help my i need bios
    Originally posted by hamada2h
    pls help my
    i need bios
    DA0VM9MB6B0 REV B
    rev: A01
    PWA: m712H
    post the full name and model of the laptop and the original bios even if it is corrupted...
    • hamada2h
      • Nov 2018
      • 7
      • egypt
      Vostro A860 dell
      • hardware1
        • Sep 2021
        • 2949
        • N/A
        Vostro A860 dell
        Upload your original backup bios file.
        all donations are welcome,
        • hamada2h
          • Nov 2018
          • 7
          • egypt
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            Re: pls help my i need bios Vostro A860
            Looks like you have a second chip that hasn't been posted here.
            • FalconPunch
              Surface Pro X 1876 Bios corrupted
              by FalconPunch
              Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
              Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
              08-09-2025, 03:56 AM
            • zlr8r
              Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
              by zlr8r
              Greetings
              I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
              Serial Number: 5CG3202C16
              Product #/SKU: 739P0AV
              CT Number: PRTUE00WBI30YX
              Description: HP ZBook Firefly 14 inch G10
              BuildID: 23WWWGAZ602#SABU#DABU
              Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
              MAC address not found.
              • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
              10-28-2025, 01:56 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • TylerHyde21
              Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
              by TylerHyde21
              Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
              I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
              I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
              This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
              06-29-2024, 10:38 AM
            • Loli Popu
              DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
              by Loli Popu
              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
              12-13-2024, 08:29 AM
