Latitude 7430 bios
  • aldopc
    • Jul 2017
    • 465
    • Chilito
    Re: Latitude 7430 bios
    Originally posted by santoslao
    Please help me with removing BIOS password from the attached dump
    Thanks!
    Hi Test and comments
    • ramkaskad12
      • May 2018
      • 54
      • ukraine
      Help me to unlock dell 7430
      • qayyum786
        • Aug 2018
        • 1955
        • INDIA
        Originally posted by ramkaskad12
        help me to unlock dell 7430
        try
        • ramkaskad12
          • May 2018
          • 54
          • ukraine
          Originally posted by qayyum786
          try
          it worked thanks
          • feherhollo
            • Nov 2019
            • 110
            • Hungary
            The only solution is to cut vcc tracks from the bios chip 256.
            So you need to cut motherboard or remove the chip? No way to do elsewhere without physical damage?
            • santoslao
              • Apr 2017
              • 131
              • BZ
              #26
              this is just an option, but there is no other way than to remove the chip and use an adapter.
              • feherhollo
                • Nov 2019
                • 110
                • Hungary
                #27
                Thanks. I think there is no other way to read out chip by cable on circuit like before. I had the same experience with other 12gen latitude models like 5430,5431 and 7430. Unable to read and erase correctly on circuit.
                • santoslao
                  • Apr 2017
                  • 131
                  • BZ
                  #28
                  unfortunately these new models cannot, you are forced to remove the chip from its place or make a cut in the VCC track of the chip.
                  • elniñodelcautin
                    • Jul 2023
                    • 16
                    • bogota
                    #29
                    Help I have computrace active I need to deactivate HELP PLEASE
                    Servise tag:421vpn3
                    • santoslao
                      • Apr 2017
                      • 131
                      • BZ
                      #30
                      Servise tag:421vpn3
                      computrace is on the other chip!
                      • elniñodelcautin
                        • Jul 2023
                        • 16
                        • bogota
                        #31
                        here is the second bios chip
                        help remove computerace please thank you
                        • mkhalid2
                          • Mar 2022
                          • 3
                          • world
                          #32
                          Plz i need help to know the Dell latitude 7430 bios chip ,i see 3 of them see att
                          • aldopc
                            • Jul 2017
                            • 465
                            • Chilito
                            #33
                            It's the biggest chip.
                            • MAZMAZ23
                              • Jan 2023
                              • 33
                              • ALGER
                              #34
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #35
                                Read the rules before posting:
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • MAZMAZ23
                                  • Jan 2023
                                  • 33
                                  • ALGER
                                  #36
                                  OK
                                  LATITUDE 7430
                                  ST 1RYTW3
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12139
                                    #37
                                    Originally posted by mazmaz23
                                    ok
                                    please help me with removing bios password from the attached dump
                                    latitude 7430
                                    st 1rytw3
                                    st 1rytw3
                                    • MAZMAZ23
                                      • Jan 2023
                                      • 33
                                      • ALGER
                                      #38
                                      it worked thanks
                                      • khaledmosa99
                                        • 75
                                        • egypt
                                        #39
                                        plz need unlock this one
                                        • Markus1741
                                          • Sep 2020
                                          • 873
                                          • N/A
                                          #40
                                          Hello i will try to help you but first we need your Service Tag its a Rule hear ....
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                            DELL Latitude 7430 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7430 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7430 boardview and 7430 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7430...
                                            09-07-2024, 07:19 AM
                                            09-07-2024, 06:31 AM
                                          • Loli Popu
                                            DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                            by Loli Popu
                                            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                            12-13-2024, 08:29 AM
