Support for Samsung NP300E7A
  • Toncino
    • Nov 2022
    • Italia
    I need to update the BIOS of the NP300E7A Samsung laptop, but I can't do that under Windows 10:
    - Installing the Samsung Update application from Store does not work (the application will just remain stuck).
    - With BIOSUpdate.exe I could download the latest verision of the BIOS ("ITEM_20130312_816_WIN_09QA.exe"), but when I try to flash it, I get a blue screen. I did try to run the application in compatibility mode, but no luck.
    I have the feeling that the issue is related to Windows 10, so I was wondering if there is any DOS application to update the BIOS (I can extract the BIOS from "ITEM_20130312_816_WIN_09QA.exe" with WinRAR, I hope that is correct).
    I know it is a very old laptop, any suggestion will be GREATLY appreciated!
    EDIT: I tried to use winphlash64-1.0.76, but the bios file I have does not seem to be compatible with this application.
  • Toncino
    • Nov 2022
    • Italia
    Re: Support for Samsung NP300E7A
    Nevermind, I found a very fancy way to fix this by reinstalling Windows 7 on a random disk and using the BIOS update application. All done!
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • akwky
      by akwky
      Hi!
      04-14-2025, 01:56 PM
    • al3m0di
      Update bios EFCN58WW to EFCN59WW
      by al3m0di
      Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
      I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
      The BIOS version is EFCN58WW.
      When I turn on the device, it displays the message:
      "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
      The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
      I've tried
      07-29-2024, 10:32 AM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
