Unowhy Y13 BIOS Password Request
tryAttached Filesif you find these attachements useful please consider making a small donation to the site
PLEASE UNPASS THIS BIOSAttached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
https://www.badcaps.net/donateComment
Can someone unlock this bios dump please
IFP137119986
LaPoste: M1900025L3/N012B/2021
Y13G011S4EI
hi freinds please remove pesword bios for me unowhy em_js116_2008_ene_v1.0
y13g113s4ei
n:ifp328144605
laposte/m1900025l3/n0011d/2023Attached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Can you test this patched file and provide some feedback?
The first startup may take a longer time, this is normal...be patient... first startup may take a long time, this isAttached Filesif you find these attachements useful please consider making a small donation to the site
PLEASE UNLOCK THIS BIOS
Y13 2024 LOCKED
EM_JS168_S_V3.0
SN / IFP426090616Attached Filesif you find these attachements useful please consider making a small donation to the site
hi tryAttached Filesif you find these attachements useful please consider making a small donation to the site
[QUOTE=shiyab;n3724996]
Channel: BIOS Requests ONLY!
by Godfather79Hello everyone in the community
Dear Sir,
I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
Problem details:
* Model: Dell Latitude 5520.
* Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
* Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
* Service Tag: (Enter your actual Service Tag from the laptop here)
* BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by touftaf7301Hello everyone,
I have an ASUS TUF A17 (model TUF707NV-HX088W, motherboard NJS / DA0NJSMBAF0 Rev F) that is locked by an UEFI BIOS password.
I have already checked the BIOS guides, methods, resources and tools section but could not find a working method for this specific model.
Details:
– Make/Model: ASUS TUF A17 TUF707NV-HX088W
– Motherboard: NJS / DA0NJSMBAF0 Rev F
– Serial number: S7NRCX05W03829E
– Issue: UEFI BIOS password locked (no access to BIOS setup or boot options)
– BIOS dump attached below (read with RT809F)...-
- Loading...
