Lenovo Y470N BIOS white-list wlan removal request
  • hotxboy
    • Feb 2022
    • 17
    • Hong Kong
    I have a old laptop Lenovo Y470N which is a old model with no UEFI BIOS boot option and the builtin BIOS restricts wlan cards known as white-list WLAN cards. I need to update the CPU microcode and remove the white-list WLAN cards function. Tried to the old fashioned way of hex replacement of vender-ID and device-id method but not very useful, I have to do this all over again after new wlan card and this method turns out freezing the laptop sometime. If possible I also need to enable UEFI boot function. Any help would be appreciated.
    BIOS dump attached below. The BIOS is Insyde legacy BIOS.
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • Wahaz
    by Wahaz
    10-30-2023, 08:42 PM
  • grimacelord
    by grimacelord
    Hello there.
    History:
    03-15-2023, 03:29 PM
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • xsd611
    Lenovo X270 Bios - remove Whitelist
    by xsd611
    ​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
    07-13-2025, 09:13 PM
